It is currently Wed Nov 25, 2026 3:50 am
 Post subject: Custom Font File User Splicer for Gimp 2.10
PostPosted: Fri Sep 27, 2024 3:09 pm  (#1)
Download, unzip and place the filter in your Gimp user plug-ins folder.
Custom_Font_File_User_Splicer_01.zip [4.9 KiB]
Downloaded 113 times
A pdf version of this short guide:
Custom Font File User Splicer for Gimp 2pt10.pdf [123.22 KiB]
Downloaded 90 times
This is another utility for breaking up custom font files into smaller files. This plug-in allows you to choose the number of files and how many layers each file should contain.
You can quickly find out how many layers a file has by opening a custom font file and looking at the title bar.
The one below shows you that the image file contains 87 layers.
If you need more information about the characters contained in the custom font, you can use another custom font utility, Custom Font Size Reducer, to analyse the contents of the file.
Once you have decided how many files you need to make and how many layers you wish to have in each file, open the filter dialog:
Filters>>Custom Fonts>>Utility Tools>>Custom Font File User Splicer v01…
Use the first option to enter the number of files you wish to generate and then enter the number of layers to place in each of the files before clicking on ‘OK’.
The filter will then display and/or save the layers according to the outcome that you select with the last option.
If the number of layers chosen does not add up to the number of layers contained in the file, the plug-in will throw up a message box to suggest how many layers need to be added or removed from your selection options in order to continue.
The example folder view below shows one of my recent custom fonts after using the filter, together with compressed versions of the files -
(the original file started out with a size of 17.6 Mb):
The files can be re-assembled with the Stitcher plug-in.
 Post subject: Re: Custom Font File User Splicer for Gimp 2.10
PostPosted: Sat Sep 28, 2024 3:03 am  (#2)
Thank you so much for your awesome work in this new help filter. :tyspin :clap
I have a custom font which has 65 layers and it is 32.5 Mb
I have got 5 split items and they done in zip. but the second one is rather bigger than the others.
Sorry, I don't understand it as there are the same number of layers as the others ones. (used the new plug-in)
I feel :oops: I don't know how to do it correctly.
I post the custom in the thread.
PostPosted: Sat Sep 28, 2024 7:10 am  (#3)
:gaah
Have had a look to try and come up with a strategy for you Issabella and how to explain it.
Think I am nearly there.
:hi5
Have had to adjust the layer per file number options to cater for your size of character so a new version will appear soon.
Screenshot to show your file split into 5 smaller files (I do not think that it will not fit into 4 files smaller than 6 Mb):
PostPosted: Sat Sep 28, 2024 8:50 am  (#4)
Thank you so much Skinnyhouse. I'm beeing a pain in the neck. Sorry
But you always a find a real solution. It's great you have got all of the files in less than 6 Mb. :tyspin :hi5 :clap
PostPosted: Sun Sep 29, 2024 11:31 am  (#5)
it slices! it dices! it juliennes!!!
PostPosted: Mon Sep 30, 2024 10:05 am  (#6)
:hehe
PostPosted: Mon Sep 30, 2024 10:07 am  (#7)
I'm so happy with this plug-in. The large Custom Fonts aren't a problem now.
Thanks a lot. :tyspin :clap
