It is currently Tue Nov 17, 2026 11:21 am
 Post subject: GEGL renders Earth Like Planet Maps
PostPosted: Sat Sep 28, 2024 8:42 am  (#1)
Its a random seed for Continents and Islands, with the ability to control continent size recolor the land and water and cast random lighting.
GMIC gives it sphere mapping ( I had to use 2.10 for this since 2.99.19 doesn't have GMIC)
Code, and Windows and Linux binaries inside zip.
earth_plugin.zip [88.42 KiB]
Downloaded 134 times
LOCATION TO PUT BINARIES
Windows
Linux
then restart GIMP go to GEGL Operation and look for "Earth" if you are in 2.99.16+ look for Filters/render/fun/earth
 Post subject: Re: GEGL renders Earth Like Planet Maps
PostPosted: Sat Sep 28, 2024 9:03 am  (#2)
Very cool :bigthup
PostPosted: Sat Sep 28, 2024 9:27 pm  (#3)
Earth Map is on Github and it was given a new noise reduction slider
https://github.com/LinuxBeaver/GEGL-GIM ... Earth_Map/
PostPosted: Sat Mar 21, 2026 10:25 pm  (#4)
Windows updated Binary here for 3.0.8+ no need to provide duplicates of anything else as the code is the same
earth_windows_binaries_gegl_plugin.zip [1.07 MiB]
Downloaded 82 times
