It is currently Wed Nov 25, 2026 4:18 am
 Post subject: Custom Font File User Splicer v02 for Gimp 2.10
PostPosted: Sat Sep 28, 2024 2:22 pm  (#1)
This update allows for a greater range of layers to be used for each file generated (5 - 50) which I think will work better with larger custom font image sizes - otherwise the dialog remains exactly the same as in version 01.
Download, unzip and place the filter in your Gimp user plug-ins folder.
Custom_Font_File_User_Splicer_02.zip [4.9 KiB]
Downloaded 106 times
I have outlined a strategy to use with the plug-in in the pdf below (it is too wordy to include here).
Custom Font File User Splicer for Gimp 2pt10.pdf [123.22 KiB]
Downloaded 53 times
 Post subject: Re: Custom Font File User Splicer v02 for Gimp 2.10
PostPosted: Sun Sep 29, 2024 2:17 am  (#2)
:clap :yes
Thank you so much Skinnyhouse. You have got with your last plug-ins we have much easier to split the large custom fonts in the correct number files.
:tyspin :bigthup
PostPosted: Sun Sep 29, 2024 3:46 am  (#3)
I hope it is of some use to you Issabella.
Sadly I can find no easy answer to fully automating the process using Gimp scripting tools.
Of course you do build up a feel for how certain custom fonts and decorative finishes can be split up.
Some textures and effects compress much better than others.
I did a little test based on your Longdom custom font using the same edge with a two tone inner panel given a quick shine effect:
The file info below shows that the uncompressed file is not much smaller (4 Mb) than the original but it has a much better compression rate - almost halving the size of the file.
