It is currently Wed Nov 25, 2026 1:10 am
 Post subject: Update for Custom Font Splitter to v0.3 for Gimp 2.10
PostPosted: Fri Oct 11, 2024 7:06 am  (#1)
Here is a small update to fix a problem when re-assembling a custom font which uses a number as the last charcter in the filename.
If you need it; download, unzip and place it in your user plug-ins folder.
Custom_Font_File_Splitter_03.zip [4.23 KiB]
Downloaded 59 times
Look in:
Filters>>Custom Fonts>>Utility Tools
It simply appends the characters '-CF' to the filename when saving the parts of the file.
Example when splitting into two files:
Old filename New filenames
12345.xcf 12345-CF.xcf, 12345-CF_1.xcf
Alan5.xcf Alan5-CF.xcf, Alan5-CF_1.xcf
Skinny5file.xcf Skinny5file.xcf, Skinny5file_1.xcf
 Post subject: Re: Update for Custom Font Splitter to v0.3 for Gimp 2.10
PostPosted: Fri Oct 11, 2024 9:23 pm  (#2)
Thanks Skinnyhouse! :)
PostPosted: Sat Oct 12, 2024 1:48 am  (#3)
Nice!
Thanks Skinnyhouse,
Seems you're pretty much the "GOTA" of fonts around here.
