It is currently Tue Nov 24, 2026 9:02 am
 Post subject: Selecting Alternating Diagonals Plug-in
PostPosted: Thu Oct 24, 2024 5:48 am  (#1)
For when you want to make plaid-patterns with solid color diagonals instead of 50% opacity
Alternately, you can do a manual slower method by erasing every other line on a solid layer then rotate 45 degrees but then your solid layer has to be larger than your plaid design area. And it's slower to erase lines and rotate
that's why this plug-in is here.
It simply makes selections of alternating diagonals so that you can use to delete the top layer of your plaid design in one direction to reveal the bottom layer of the other direction of plaid pattern.
bottom layer, plaid design of one direction
top layer, plaid design of 2nd direction
run plug-in to make diagonals selection and delete from top layer to reveal part of 2nd layer. Done
Plug-in code below
#!/usr/bin/env python
# Author: (Tin Tran)
# Created On: 2024.08.03
# My own grunty bot/script that will take select alternating diagonals
# to delete from top layer to reveal lower layer to create plaid-patterns.
# Spawned/Inspired by my http://plaid-patterns.com javascript plaid designer.
# License: Whatever GIMP's License is.
# Revisions:
# Rel 0.10: Initial Version
from gimpfu import *
import random
import math
import os
def select_diagonals(image,layer,dia_hor_width):
    double_edge = layer.width+layer.height #get sum of width and height
    y1 = 0; y2 = 0; #these don't change because we're going right to the edges
    x3 = 0; x4 = 0;
    pdb.gimp_selection_none(image) #clear selection because we'll be selecting diagonals
    for i in range(0,int(math.ceil(double_edge/dia_hor_width))):
        if (i % 2 == 0): #alternating it
            x1 = i*dia_hor_width
            x2 = (i+1)*dia_hor_width
            y3 = (i+1)*dia_hor_width
            y4 = i*dia_hor_width
            #select each diagonal stripe
            pdb.gimp_image_select_polygon(image,CHANNEL_OP_ADD,8,[x1,y1,x2,y2,x3,y3,x4,y4])
register(
    "python_fu_select_diagonals",
    "description",
    "longer description",
    "author name",
    "copyright name",
    "2024.10.24",
    "A Select Diagonals",
    "RGB*",      # Alternately use RGB, RGB*, GRAY*, INDEXED etc.
    #INPUT BEGINS
    (PF_IMAGE, "image", "Image", None),
    (PF_DRAWABLE,   "layer", "Drawable", None),
    (PF_INT, "dia_hor_width", "Diagonal Horizontal Width:", 4),
    #INPUT ENDS
    select_diagonals,
    menu="<Image>/Python-Fu")
main()
# Below is all the example input types for INPUTS for the plug-in which can be cut and pasted into #INPUT BEGINS section and edited to taste (found online years back that I didn't want to constantly look up)
# Since GIMP is free anyways, I thought it would be handy here for me to CUT and PASTE, CHANGE, USE.
#           (PF_INT, "p0", "_INT:", 0), # PF_INT8, PF_INT16, PF_INT32  similar but no difference in Python.
#           (PF_FLOAT, "p02", "_FLOAT:", 3.141),
#           (PF_STRING, "p03", "_STRING:", "foo"),  # alias PF_VALUE
#           (PF_TEXT, "p04", "TEXT:", "bar"),
#           # PF_VALUE
#           # Pick one from set of choices
#           (PF_OPTION,"p1",   "OPTION:", 0, ["0th","1st","2nd"]), # initially 0th is choice
#           (PF_RADIO, "p16", "RADIO:", 0, (("0th", 1),("1st",0))), # note bool indicates initial setting of buttons
#           # PF_RADIO is usually called a radio button group.
#           # SLIDER, ADJUSTMENT types require the extra parameter of the form (min, max, step).
#           (PF_TOGGLE, "p2",   "TOGGLE:", 1), # initially True, checked.  Alias PF_BOOL
#           # PF_TOGGLE is usually called a checkbox.
#           (PF_SLIDER, "p3", "SLIDER:", 0, (0, 100, 10)),
#           (PF_SPINNER, "p4", "SPINNER:", 21, (1, 1000, 50)),  # alias PF_ADJUSTMENT
#           # Pickers ie combo boxes ie choosers from lists of existing Gimp objects
#           (PF_COLOR, "p14", "_COLOR:", (100, 21, 40) ), # extra param is RGB triple
#           # PF_COLOUR is an alias by aussie PyGimp author lol
#           (PF_IMAGE, "p15", "IMAGE:", None), # should be type gimp.image, but None works
#           (PF_FONT, "p17", "FONT:", 0),
#           (PF_FILE, "p18", "FILE:", 0),
#           (PF_BRUSH, "p19", "BRUSH:", 0),
#           (PF_PATTERN, "p20", "PATTERN:", 0),
#           (PF_GRADIENT, "p21", "GRADIENT:", 0),
#           (PF_PALETTE, "p22", "PALETTE:", 0),
#           (PF_LAYER, "p23", "LAYER:", None),
#           (PF_CHANNEL, "p24", "CHANNEL:", None),  # ??? Usually empty, I don't know why.
#           (PF_DRAWABLE, "p25", "DRAWABLE:", None),
#           # Mostly undocumented, but work
#           (PF_VECTORS, "p26", "VECTORS:", None),
#           (PF_FILENAME, "p27", "FILENAME:", 0),
#           (PF_DIRNAME, "p28", "DIRNAME:", 0)
#           # PF_REGION might work but probably of little use.  See gimpfu.py.
 Post subject: Re: Selecting Alternating Diagonals Plug-in
PostPosted: Thu Oct 24, 2024 6:39 am  (#2)
A very interesting possibility. :hi5
PostPosted: Thu Oct 24, 2024 8:15 am  (#3)
Yeah this is going to be an interesting filter to play with. I am thinking along the engrave possibilities. ;)
PostPosted: Thu Oct 24, 2024 10:06 am  (#4)
I don't know much about that engraving stuff. But anything it can be used for is cool. :D
PostPosted: Thu Oct 24, 2024 6:31 pm  (#5)
This version is slightly faster since it tries to only select within the image and not outside of it
# Revisions:
import random
import math
import os
    x3 = 0; x4 = 0;
            if x1 > layer.width: #a corner reached for point 1 and 2
                y1 = x1-layer.width
                x1 = layer.width
                y2 = x2-layer.width
                x2 = layer.width
            if y4 > layer.height: #a cornder reached for point 3 and 4
                x3 = y3 - layer.height
                y3 = layer.height
                x4 = y4 - layer.height
                y4 = layer.height
register(
    "description",
    "author name",
    "copyright name",
    "2024.10.24",
    #INPUT BEGINS
    #INPUT ENDS
    select_diagonals,
main()
#           # PF_VALUE
PostPosted: Fri Oct 25, 2024 4:24 am  (#6)
What i was thinking was that if you have a bunch of different black and white line layers going different directions you could use a layer mode to effect an engraved look. Especially if you could use paths to create the lines.
PostPosted: Mon Oct 28, 2024 10:49 pm  (#7)
fun with google notebook LM
PostPosted: Tue Oct 29, 2024 1:49 am  (#8)
Nice job Tran! :)
PostPosted: Tue Oct 29, 2024 9:12 am  (#9)
Nice job Tran! :)
I didn't do anything, notebook LM is smart enough to talk about anything.
PostPosted: Thu Oct 31, 2024 3:00 am  (#10)
Tin, your plug-in is great and very useful to decorate. Thanks a lot. :coolthup
PostPosted: Fri Nov 01, 2024 4:26 am  (#11)
The plugin is very fast - it takes less time to start than to execute (I even thought for a moment that it didn't work).
I took the liberty of extending Your plugin.
A few small examples:
Edit:In order not to confuse the thread, this version will be continued here:
viewtopic.php?f=9&t=21469
Striped Selection.zip [2.02 KiB]
Downloaded 206 times
PostPosted: Fri Nov 01, 2024 1:05 pm  (#12)
Wow, so many options.
PostPosted: Sat Dec 07, 2024 1:22 pm  (#13)
for kicks I have shared this on mybb forum a brand-spanking new forum that I just created for hopefully plaid-patterns.com related or patterns related stuff https://plaid-patterns.com/myBB/Upload/ ... .php?tid=2
PostPosted: Sat Dec 07, 2024 2:30 pm  (#14)
This is exactly what i was talking about. If you could add wavy lines it would result in a really good engraver effect i think. Like the lines on money.
PostPosted: Sat Dec 07, 2024 3:46 pm  (#15)
wavy line you say.... I wonder..... if it's simple enough to hack out somehow.
Time to do go some money wavy lines research.
PostPosted: Sat Dec 07, 2024 4:26 pm  (#16)
Ok, research is complete.
Here's the final product "A Select Waves". You can adjust wave-length and wave-height (which is the height from bottom of a wave to top of single wave not including thickness of wave).
Here's the code below (and attached zipped .py file):
# Revisions:
import random
import math
import os
def select_waves(image,layer,wavelength,waveheight):
    waveheight = waveheight/2; #only take half because we're dealing with math.sin
    coords1 = [];
    coords2 = [];
    for x in range(0,layer.width):
        y = math.sin((x*1.0/wavelength)*2.0*math.pi)*waveheight - waveheight*3;
        coords1.append(x)
        coords1.append(y)
        coords2.append(x)
        coords2.append(y+waveheight);
    coords2r = []
    for i in range(len(coords2)-1,-1,-2):
        coords2r.append(coords2[i-1])
        coords2r.append(coords2[i])
    coords = coords1+coords2r;
    for i in range(-waveheight*2,layer.height,waveheight*2):
        for j in range(0,len(coords),2):
            coords[j+1] += waveheight*2;
        pdb.gimp_image_select_polygon(image,CHANNEL_OP_ADD,len(coords),coords)
register(
    "python_fu_select_waves",
    "description",
    "author name",
    "copyright name",
    "2024.10.24",
    "A Select Waves",
    #INPUT BEGINS
    (PF_INT, "wavelength", "Wave-Length (pixels):",50),
    (PF_INT, "waveheight", "Wave-Height (pixels):",25),
    #INPUT ENDS
    select_waves,
main()
#           # PF_VALUE
Shared to https://plaid-patterns.com/myBB/Upload/ ... .php?tid=4
File comment: select waves.py
select-waves.zip [2.02 KiB]
Downloaded 102 times
PostPosted: Sat Dec 07, 2024 4:38 pm  (#17)
Thanks Tran!! I will be playing with this to make some money custom font. :)
PostPosted: Sat Dec 07, 2024 4:46 pm  (#18)
Right on! you're welcome it was was fun building and testing it.
PostPosted: Sat Dec 07, 2024 5:26 pm  (#19)
Here's "A Select Zigzag" letting specifying wave-length, wave-height.
Here's the code [attached is zipped .py file]:
# Revisions:
import random
import math
import os
def select_zigzag(image,layer,wavelength,waveheight):
    coords1 = [];
    coords2 = [];
    count = 0;
    for x in range(0,layer.width+wavelength,wavelength/2):
        if (count % 2 == 0):
            y = -waveheight*4;
        else:
            y = -waveheight*2;
        count += 1; #alternate zig and zag
        coords1.append(x)
        coords1.append(y)
        coords2.append(x)
    coords2r = []
register(
    "python_fu_select_zigzag",
    "description",
    "author name",
    "copyright name",
    "2024.10.24",
    "A Select Zigzag",
    #INPUT BEGINS
    #INPUT ENDS
    select_zigzag,
main()
#           # PF_VALUE
Shared to https://plaid-patterns.com/myBB/Upload/ ... .php?tid=5
File comment: zipped .py file of code.
select-zigzag.zip [2.06 KiB]
Downloaded 99 times
PostPosted: Sat Dec 07, 2024 6:39 pm  (#20)
"A Select Swiggly" aka "curly braces wave select"
Code below (and attached zipped .py file)
# Revisions:
import random
import math
import os
def select_swiggly(image,layer,wavelength,waveheight):
    coords1 = [];
    coords2 = [];
    count = 0;
    for x in range(0,layer.width+wavelength):
        mod_value = x % (wavelength*2)
        if mod_value <= wavelength:
            ix = mod_value  # 1 to 6
            y = math.sin((x*1.0/wavelength)*2.0*math.pi)*waveheight+ix;
        else:
            ix = wavelength*2 - mod_value  # 5 to 1
            y = -math.sin((x*1.0/wavelength)*2.0*math.pi)*waveheight+ix;
        y -= wavelength;
        coords1.append(x)
        coords1.append(y)
        coords2.append(x)
    coords2r = []
register(
    "python_fu_select_swiggly",
    "description",
    "author name",
    "copyright name",
    "2024.10.24",
    "A Select Swiggly",
    #INPUT BEGINS
    #INPUT ENDS
    select_swiggly,
main()
#           # PF_VALUE
Shared to https://plaid-patterns.com/myBB/Upload/ ... .php?tid=6
select-swiggly.zip [2.11 KiB]
Downloaded 82 times
