It is currently Tue Nov 17, 2026 4:17 pm
Post new topic Reply to topic  [ 86 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Download all 90 GEGL plugins of mine to prevent a GIMP 3 crash
PostPosted: Fri Nov 29, 2024 2:00 pm  (#1)
I found a new crash in GIMP 3 that happens with image upload based GEGL plugins of mine. Technically only 35+ something plugins updated but I decided to just wrap all 90 plugins; which is everything. It is not likely most users will trigger the crash but here's the fix. The crash force closes GIMP so you'd lose all work if it happens.
All 90+ GEGL plugins below - crash free
LinuxBinaries.zip [811.44 KiB]
Downloaded 3611 times
WindowsBinaries.zip [3.19 MiB]
Downloaded 4112 times
source_code_of_all_GEGL_plugins.zip [2.62 MiB]
Downloaded 3414 times
Also off topic this ships with my new plugin Text Logo Maker, my new text styling engine that is simpler then GEGL Effects but faster, much faster when doing live text editing. Above you can see a pic of it.
LOCATION TO PUT BINARIES
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
Also I wouldn't mind using this thread to discuss the weakness of GEGL plugins. Unlike normal plugins they actually crash GIMP when they crash, always without exception as they are not independent/containerized like script fu, gmic and python stuff. The only way GIMP team can fix this is to make a container for GEGL plugins like script fu and python have but that would take A LOT of work.
 Post subject: Re: Download all 90 GEGL plugins of mine to prevent a GIMP 3 crash
PostPosted: Fri Nov 29, 2024 3:50 pm  (#2)
I don't know if you can containerize them if they are utilized in non destructive layer effects Beaver. Because it seems if any GEGL plug-in that is used on a layer effect fails, then that effect will also become void as well.
Maybe if you could merge layer effects to contain them in case of a crash, and then unmerge them if they needed to be adjusted? Perhaps merging them before a crash.
Thanks for the update by the way.
I have not had any issues with your last set of plug-ins but i will replace them just in case.
PostPosted: Mon Dec 02, 2024 6:28 am  (#3)
@contrast_
It's great to be able to download all your filters from GimpChat too.
Gegl has a description of the operations:
https://gegl.org/operations/
Are you planning something similar for your plugins?
PostPosted: Mon Dec 02, 2024 7:26 am  (#4)
MareroQ wrote:
@contrast_
Every Github profile has descriptions of my plugins, even GimpChat pages talk about them. I don't know if I should mimic Pippin's format at gegl.org.
PostPosted: Mon Dec 02, 2024 7:44 am  (#5)
The Pippin format has the advantage of listing the next variables and their scope. If this cannot be achieved semi-automatically from the source file (.c) then I understand that for 91 filters it is too tedious a task. :crash
PostPosted: Mon Dec 02, 2024 11:39 am  (#6)
its very easy now for me to compile all my plugins. Back in 2023 I had a sloppy disorganized workflow now things are type/click and go
Attached is latest source code and binaries of everything (except bash plugin), no emergency if you already updated here. Just a few new filters like Orton and minor changes elsewhere
source_code_of_all_GEGL_plugins.zip [3.67 MiB]
Downloaded 3397 times
LinuxBinaries.zip [824.04 KiB]
Downloaded 3335 times
WindowsBinaries.zip [3.25 MiB]
Downloaded 3324 times
PostPosted: Mon Dec 02, 2024 2:20 pm  (#7)
In case of duplicate plugins or scripts, the first one encountered is loaded.
I wonder how it looks in the case of Gegl in Gimp 3?
Are your plugin updates included in the filters available by default in Gimp 3?
A lot of messages (I know they were always there, but they have increased significantly)
PostPosted: Mon Dec 02, 2024 2:29 pm  (#8)
There should only be one of each plugin without duplicates
PostPosted: Mon Dec 02, 2024 2:56 pm  (#9)
No none of my plugins are default in GIMP 3.
The defaults are "Styles", "Inner Glow" and "Bevel" and they are gegl: namespaced, not lb: name spaced.
PostPosted: Wed Dec 04, 2024 2:21 pm  (#10)
Thanks for the plugins. I will save them and use them when gimp 3.0 is officially released.
PostPosted: Wed Dec 04, 2024 4:33 pm  (#11)
Latest Update, Inner Glow and Misc Bevel Collect updated to use a crop with aux.
LinuxBinaries_all_plugins.zip [4.22 MiB]
Downloaded 3341 times
WindowsBinaries_all_plugins.zip [3.22 MiB]
Downloaded 3280 times
source_code_of_all_GEGL_plugins.zip [3.66 MiB]
Downloaded 3291 times
PostPosted: Thu Dec 05, 2024 8:52 pm  (#12)
Let me clarify. Micro updates to my plugins happen all the time like this I just wait for many of them before alerting the public. Now I tell everyone every time something little changes.
GEGL Effects image opacity switch was broke this update fixes it. Other then that no changes have been made. The latest GEGL Effects is Dec 5 2024
Downloaded 3302 times
Downloaded 3300 times
Downloaded 3269 times
PostPosted: Fri Dec 06, 2024 9:11 pm  (#13)
1. Photo to Cartoon 2 had a mistake where it used the GEGL name space (gegl: was changed to lb:)
2. Mini shape inprints was added
No other changes and from here on I'm only going to alert on updates when something big happens this is getting ridiculously but mini updates like this happen all the time I just keep quiet and only alert the public when serious updates happen.
Downloaded 3290 times
LinuxBinaries_all_plugins.zip [4.23 MiB]
Downloaded 3289 times
WindowsBinaries_all_plugins.zip [3.25 MiB]
Downloaded 4506 times
PostPosted: Sat Mar 08, 2025 4:32 am  (#14)
GEGL's lead developer broke presets on GEGL inner glow and all plugins of mine that use it. Including GEGL effects.
If you update the presets will load accurate. If you don't update all GEGL inner glow presets above 1.0 will be set to 0.5 making them semi translucent. That's all the March 8 2025 GEGL Effects update goes
LinuxBinaries_all_plugins.zip [862.47 KiB]
Downloaded 3394 times
WindowsBinaries_all_plugins.zip [3.4 MiB]
Downloaded 3330 times
source_code_of_all_GEGL_plugins.zip [4.11 MiB]
Downloaded 3287 times
PostPosted: Sat Mar 08, 2025 7:46 pm  (#15)
Thank you for the updated plug-ins Beaver.
PostPosted: Mon Mar 17, 2025 8:05 pm  (#16)
Download to all plugins of mine updated March-16-2025
This may be the final update ever, two things changed so far.
1. A breakage with my plugin GEGL Metallic was fixed
2. Edge Bevel was updated to use a different default preset
LinuxBinaries_all_plugins.zip [3.4 MiB]
Downloaded 3276 times
WindowsBinaries_all_plugins.zip [5.96 MiB]
Downloaded 3339 times
source_code_of_all_GEGL_plugins.zip [2.81 MiB]
Downloaded 3885 times
Now that GIMP 3's released I can a guarantee stability on that particular version of GIMP forever.
PostPosted: Fri Mar 28, 2025 11:29 pm  (#17)
In this update I renamed three filters without breaking non-destructive edits or presets. The operation name is still the same but titles and sliders are different
Bevel (to blend) now has different slider names with a working azimuth slider
Sharp Bevel was renamed to Sharp Chamfer Bevel
Custom Bevel was renamed to Bump Bevel
source_code_of_all_GEGL_plugins.zip [2.82 MiB]
Downloaded 3304 times
LinuxBinaries_all_plugins.zip [3.41 MiB]
Downloaded 3323 times
WindowsBinaries_all_plugins.zip [3.46 MiB]
Downloaded 3422 times
PostPosted: Wed Apr 16, 2025 4:52 pm  (#18)
Source code and binaries of over 105+ GEGL plugins.
1. A new version of GEGL Effects is released called just "GEGL Effects" (lb:effects)it can co-exist with all the others versions of GEGL Effects. It has a better outline only ability and easier to use gradient. One new thing about it is that it locks sliders that require a checkbox to use. meaning certain sliders will not move until their checkbox is active.
2. a filter called "Day one" was released which is a mimick of GEGL Effects the day it was first released May 11 2022
3.a generic plugin called "outline" that does an outline and nothing else was released based on one of the first proto plugins I made but never released. Though the code was rewritten from scratch
4. A important but unnoticable change is that GEGL Effects Classic edition (lb:layereffects) was modified so it no longer applies emboss at 1% at startup. The vast majority of users of this plugin will not notice the difference because it is obviously difficult to see a filter applied at 1%.
source_code_of_all_GEGL_plugins.zip [2.87 MiB]
Downloaded 3262 times
LinuxBinaries_all_plugins.zip [3.51 MiB]
Downloaded 3205 times
WindowsBinaries_all_plugins.zip [3.64 MiB]
Downloaded 3318 times
Windows
Linux
Then restart GIMP and go to filters>generic>text styling and filters>render>fun as well as GEGL operation drop down list and other misc places to find them.
PostPosted: Fri Apr 18, 2025 3:02 pm  (#19)
Update includes all 105+ GEGL plugins on their latest versions. I confirmed all of them work on Windows 10 64bit. But Engrave was excluded from Windows due to paranoia of a crash in GIMP 2.10
LinuxBinaries_all_plugins.zip [3.53 MiB]
Downloaded 3275 times
WindowsBinaries_all_plugins.zip [3.68 MiB]
Downloaded 3362 times
Downloaded 3288 times
If Windows users want to download engrave due so manually at your own risk here
https://github.com/LinuxBeaver/GEGL-GIM ... e/releases
PostPosted: Fri Apr 18, 2025 3:32 pm  (#20)
I'm very surprised by Your comment because the plugin "Engrave Image" works perfectly in Gimp-2.10 Win10 after Your last fix.
