It is currently Tue Nov 24, 2026 7:58 am
 Post subject: GEGL motion shadow
PostPosted: Mon Dec 09, 2024 5:03 pm  (#1)
I made a new shadow plugin named "motion shadow" it is very simple, It works in both 2.10 and 3 but has more benefits in 3 because if you chain Inner Glow on top of it non-destructively it looks cooler like a flame. So basically its a drop shadow but the X and Y of the gaussian blur are in your control.
Download below
linux_binaries_gegl_plugin.zip [7.18 KiB]
Downloaded 53 times
windows_binaries_gegl_plugin.zip [33 KiB]
Downloaded 67 times
SourceCode.zip [4.27 KiB]
Downloaded 45 times
LOCATION TO PUT BINARIES
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
 Post subject: Re: GEGL motion shadow
PostPosted: Tue Dec 10, 2024 10:03 am  (#2)
Motion Shadow being applied on another plugin "Sharp bevel" and as always in GIMP 3 the text is re-editable
