It is currently Tue Nov 17, 2026 12:18 pm
 Post subject: GEGL saber effect (neon electric outline)
PostPosted: Thu Dec 12, 2024 11:27 pm  (#1)
Hello, today I made a new GEGL based plugin for GIMP that does neon electric outline that is termed "Saber" by the industry/graphics community. Enjoy and everyone is welcome to share feed back.
saber_linux_binaries_gegl_plugin.zip [15.12 KiB]
Downloaded 102 times
saber_windows_binaries_gegl_plugin.zip [66.59 KiB]
Downloaded 96 times
LOCATION TO PUT BINARIES
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
If you are on GIMP 3 beta just search for / "saber"
Saber is also on Github here
https://github.com/LinuxBeaver/GEGL-GIMP-PLUGIN_Saber
 Post subject: Re: GEGL saber effect (neon electric outline)
PostPosted: Fri Dec 13, 2024 1:51 am  (#2)
Pretty cool filter.
PostPosted: Sat Mar 21, 2026 10:07 pm  (#3)
Saber did not update but the Windows binary had to update to include gettext so it works on GIMP 3.0.8+
All the code is above. Nothing changed in the code, just internal gettext from here
https://www.gnu.org/software/gettext/
saber_windows_binaries_gegl_plugin.zip [1.07 MiB]
Downloaded 59 times
