It is currently Tue Nov 24, 2026 5:27 am
 Post subject: Plugin Curve Bend for Gimp-2.10.xx Win64bit with a larger preview.
PostPosted: Thu Jan 02, 2025 3:09 am  (#1)
This is a quite popular plugin lately. Maybe someone will find it useful with a bigger preview - then replace the curve-bend.exe file with the downloaded file (\lib\gimp\2.0\plug-ins\curve-bend\).
Remember to archive the original plugin.
In the original file curve-bend.c only the following changes were made:
from (line 79-82):
#define PREVIEW_SIZE_X   256
#define PREVIEW_SIZE_Y   256
#define PV_IMG_WIDTH     128
#define PV_IMG_HEIGHT    128
to:
#define PREVIEW_SIZE_X   572
#define PREVIEW_SIZE_Y   572
#define PV_IMG_WIDTH     512
#define PV_IMG_HEIGHT    512
curve-bend.zip [152.16 KiB]
Downloaded 88 times
 Post subject: Re: Plugin Curve Bend for Gimp-2.10.xx Win64bit with a larger preview.
PostPosted: Thu Jan 02, 2025 3:45 pm  (#2)
... although for those using max bend this version will be better (proportional enlargement x2)
#define PREVIEW_SIZE_X   512
#define PREVIEW_SIZE_Y   512
#define PV_IMG_WIDTH     256
#define PV_IMG_HEIGHT    256
Downloaded 56 times
PostPosted: Fri Jan 03, 2025 1:45 am  (#3)
Thank you MareroQ for the update. :)
