It is currently Tue Nov 24, 2026 5:05 am
 Post subject: Similar Shape Extraction plug-in - based on pixel count
PostPosted: Fri Jan 03, 2025 9:45 am  (#1)
A plug-in that I don't know if it's going to work or not for client yet but it works for my intended purpose But it's probably a basic enough functionality that I thought I would share.
#!/usr/bin/env python
# Author: Tin Tran
# Created On: 2024.11.03
# License: Open source whatever the GIMP's license is.
# Revisions:
# 0.1 Initial Version
from gimpfu import *
import os
import math
def same_shape(image,layer,tilelayer):
    pdb.gimp_image_select_item(image,CHANNEL_OP_REPLACE,tilelayer)
    mean_,std_dev,median,pixels,count1,percentile = pdb.gimp_drawable_histogram(tilelayer,HISTOGRAM_VALUE,0,1)
    pdb.gimp_image_select_item(image,CHANNEL_OP_REPLACE,layer)
    pdb.plug_in_sel2path(image,layer)
    active_vectors = pdb.gimp_image_get_active_vectors(image)
    num_strokes,stroke_ids = pdb.gimp_vectors_get_strokes(active_vectors)
    shapes = []
    #make new layer to put work on
    work_layer = pdb.gimp_layer_new(image,image.width,image.height,RGBA_IMAGE,layer.name+" after plugin",100,LAYER_MODE_NORMAL)
    pdb.gimp_image_insert_layer(image,work_layer,None,0)
    for i in range(0,num_strokes):
        temp_vectors = pdb.gimp_vectors_new(image,"shape" + str(i+1))
        pdb.gimp_image_insert_vectors(image,temp_vectors,None,0)
        type_,num_points,controlpoints,closed = pdb.gimp_vectors_stroke_get_points(active_vectors,stroke_ids[i])
        stroke_new = pdb.gimp_vectors_stroke_new_from_points(temp_vectors,type_,num_points,controlpoints,closed)
        pdb.gimp_image_select_item(image,CHANNEL_OP_REPLACE,temp_vectors)
        mean_,std_dev,median,pixels,count,percentile = pdb.gimp_drawable_histogram(layer,HISTOGRAM_VALUE,0,1)
        #if within 1 percentage difference, we consider it the same shape
        if (abs(count-count1)<count1*0.01):
            pdb.gimp_edit_copy(layer)
            float_sel = pdb.gimp_edit_paste(work_layer,TRUE)
            pdb.gimp_floating_sel_anchor(float_sel)
        #remove it when done to save memory, clean up
        pdb.gimp_image_remove_vectors(image,temp_vectors)
        #shapes.append(temp_vectors)
        #pdb.gimp_message("shape" + str(i+1) + ": " + str(count))
    pdb.gimp_selection_none(image)
register(
    "python_fu_same_shape",
    "Select same shapes",
    "author name",
    "copyright name",
    "2025.01.02",
    "A Same Shape",
    "RGB*",      # Alternately use RGB, RGB*, GRAY*, INDEXED etc.
    #INPUT BEGINS
    (PF_IMAGE, "image", "Image", None),
    (PF_DRAWABLE,   "layer", "Drawable", None),
    (PF_DRAWABLE,   "tilelayer", "Tile Layer:", None),
    #INPUT ENDS
    same_shape,
    menu="<Image>/Python-Fu")
main()
# Below is all the example input types for INPUTS for the plug-in which can be cut and pasted into #INPUT BEGINS section and edited to taste (found online years back that I didn't want to constantly look up)
# Since GIMP is free anyways, I thought it would be handy here for me to CUT and PASTE, CHANGE, USE.
#           (PF_INT, "p0", "_INT:", 0), # PF_INT8, PF_INT16, PF_INT32  similar but no difference in Python.
#           (PF_FLOAT, "p02", "_FLOAT:", 3.141),
#           (PF_STRING, "p03", "_STRING:", "foo"),  # alias PF_VALUE
#           (PF_TEXT, "p04", "TEXT:", "bar"),
#           # PF_VALUE
#           # Pick one from set of choices
#           (PF_OPTION,"p1",   "OPTION:", 0, ["0th","1st","2nd"]), # initially 0th is choice
#           (PF_RADIO, "p16", "RADIO:", 0, (("0th", 1),("1st",0))), # note bool indicates initial setting of buttons
#           # PF_RADIO is usually called a radio button group.
#           # SLIDER, ADJUSTMENT types require the extra parameter of the form (min, max, step).
#           (PF_TOGGLE, "p2",   "TOGGLE:", 1), # initially True, checked.  Alias PF_BOOL
#           # PF_TOGGLE is usually called a checkbox.
#           (PF_SLIDER, "p3", "SLIDER:", 0, (0, 100, 10)),
#           (PF_SPINNER, "p4", "SPINNER:", 21, (1, 1000, 50)),  # alias PF_ADJUSTMENT
#           # Pickers ie combo boxes ie choosers from lists of existing Gimp objects
#           (PF_COLOR, "p14", "_COLOR:", (100, 21, 40) ), # extra param is RGB triple
#           # PF_COLOUR is an alias by aussie PyGimp author lol
#           (PF_IMAGE, "p15", "IMAGE:", None), # should be type gimp.image, but None works
#           (PF_FONT, "p17", "FONT:", 0),
#           (PF_FILE, "p18", "FILE:", 0),
#           (PF_BRUSH, "p19", "BRUSH:", 0),
#           (PF_PATTERN, "p20", "PATTERN:", 0),
#           (PF_GRADIENT, "p21", "GRADIENT:", 0),
#           (PF_PALETTE, "p22", "PALETTE:", 0),
#           (PF_LAYER, "p23", "LAYER:", None),
#           (PF_CHANNEL, "p24", "CHANNEL:", None),  # ??? Usually empty, I don't know why.
#           (PF_DRAWABLE, "p25", "DRAWABLE:", None),
#           # Mostly undocumented, but work
#           (PF_VECTORS, "p26", "VECTORS:", None),
#           (PF_FILENAME, "p27", "FILENAME:", 0),
#           (PF_DIRNAME, "p28", "DIRNAME:", 0)
#           # PF_REGION might work but probably of little use.  See gimpfu.py.
File comment: zipped .py file
same-shape.zip [2.17 KiB]
Downloaded 58 times
 Post subject: Re: Similar Shape Extraction plug-in - based on pixel count
PostPosted: Sat Jan 04, 2025 1:29 am  (#2)
Interesting plug-in. This would be very useful for extracting shapes in an already existing pattern, and replacing them with a different object. Not exactly sure what i will use it for but i have a few ideas. ;)
Does the top layer have to be a brush or can it be an image of any shape in the layer you want to extract from?
Thanks Tran.
PostPosted: Sat Jan 04, 2025 7:33 am  (#3)
I just use brush as example but it can be any image of any shape.
The logic drives off of pixel counts of shapes which are separated by transparency (same logic as break apart by alpha).
PostPosted: Sat Jan 04, 2025 6:12 pm  (#4)
Gotcha! :bigthup
PostPosted: Mon Jan 06, 2025 9:28 am  (#5)
It has worked for the client. yoo hoo
PostPosted: Tue Jan 07, 2025 4:06 am  (#6)
Great news! :bigthup
PostPosted: Tue Jan 07, 2025 11:24 am  (#7)
Always wanting more clients hehe
PostPosted: Tue Jan 07, 2025 12:21 pm  (#8)
Word of mouth is always a great way to get clients ;)
PostPosted: Tue Jan 07, 2025 12:27 pm  (#9)
tell your friends hehe
