It is currently Tue Nov 24, 2026 5:16 am
 Post subject: Plugin Gradient Flare for Gimp-2.10.xx Win64bit with a larger preview.
PostPosted: Mon Jan 06, 2025 7:44 am  (#1)
Some have better equivalents in GEGL (due to the preview on canvas) - maybe someone will find it useful with a bigger preview - then replace the gradient-flare.exe file with the downloaded file (...\lib\gimp\2.0\plug-ins\gradient-flare\).
Remember to archive the original plugin.
In the original file gradient-flare.c only the following changes were made:
from (line 75,76,82,83):
#define DLG_PREVIEW_WIDTH   256
#define DLG_PREVIEW_HEIGHT  256
#define DLG_PREVIEW_MASK    GDK_EXPOSURE_MASK | \
                            GDK_BUTTON_PRESS_MASK
#define DLG_LISTBOX_WIDTH   80
#define DLG_LISTBOX_HEIGHT  40
#define ED_PREVIEW_WIDTH    256
#define ED_PREVIEW_HEIGHT   256
to:
#define DLG_PREVIEW_WIDTH   512
#define DLG_PREVIEW_HEIGHT  512
#define ED_PREVIEW_WIDTH    512
#define ED_PREVIEW_HEIGHT   512
gradient-flare.zip [172.3 KiB]
Downloaded 1652 times
