It is currently Sun Nov 22, 2026 1:11 am
 Post subject: Collected plugins with larger preview for Gimp-2.10 Win64bit.
PostPosted: Mon Jan 06, 2025 7:46 am  (#1)
I am posting here 11 plugins for Gimp-2.10.xx Win64bit with enlarged preview (they are already published on GimpChat but downloading them all at once is probably more convenient).
Included plugins:
curve-bend.exe
depth-merge.exe
flame.exe
fractal-trace.exe
gimpressionist.exe
gradient-flare.exe
lighting.exe
map-object.exe
qbist.exe
sphere-designer.exe
tile-small.exe
You can try them in bulk:
1. Create a new directory, e.g. plug-ins-big-preview
2. Copy plugins to it,
3. In Edit Preferences Folders Plugins select this directory and put it first (because they are loaded in order and duplicates are skipped).
And that's it (you don't have to swap files and archive them).
Maybe it's worth asking the developers to do this in Gimp 3 0
(minor code changes - and monitors are different than 20 years ago when these plugins were created).
plug-ins-big-preview.zip [1.33 MiB]
Downloaded 215 times
 Post subject: Re: Collected plugins with larger preview for Gimp-2.10 Win64bit.
PostPosted: Mon Jan 06, 2025 9:14 am  (#2)
That would be great!
PostPosted: Tue Jan 07, 2025 2:23 am  (#3)
If you want, you can do this with CSS in 3.0. Add this to your common.css or theme file:
-GimpPreview-size: ???;
Where ??? can be any number between 1 and 1024.
PostPosted: Tue Jan 07, 2025 4:00 am  (#4)
Thanks MareroQ. And thank you CmykStudent for the preview size hack for Gimp-3.0. :)
The idea that i can create my own size preview windows is outstanding. Especially for different size monitors.
PostPosted: Tue Jan 07, 2025 4:09 am  (#5)
@CmykStudent
Thank You for participating in the discussion. ;)
Your tip only works for some plugins.
Original preview:
GimpPreview-size: 360
None of the ones listed in #1 change the preview size. :gaah
According to my theory (because I'm not a programmer) because it has a specific size saved "hard" and probably around 20 years ago GimpPreview *preview was not used.
So possible solutions:
1. Increase the preview times 2 (easy and fast)
2. Replace "hard preview" with the function 'GimpPreview *preview' (and this requires such programming knowledge as yours).
So a request and a question for you - can you do this? :bowdown
PostPosted: Tue Jan 07, 2025 12:37 pm  (#6)
Actually it would be much neater and nicer if you could add a small button to the widget to increase or decrease the preview window. According to a users needs. :)
PostPosted: Sat Jul 19, 2025 3:23 am  (#7)
Still no larger preview via .css for GIMP 3.0.4 on Linux.
Would be so helpful to see better what the outcome would be.
The preview of Gimpressionist at least is more or less useless with such a tiny preview.
PostPosted: Wed Sep 17, 2025 5:20 am  (#8)
Ok for larger preview. Seems to skip not only the duplicates but other plugins in the original folder as well. I have GMIC in my plugins but it doesn't show now. Oh and this is in 2.10x Filters menu is much shorter
