It is currently Sun Nov 22, 2026 5:44 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: Clone Layer tool.
PostPosted: Sun Jul 10, 2011 9:08 am  (#1)
Pretty cool plugin, but only works in the beta version of GIMP. Even more specific for Windows since the only compile available (thanks samj) is 64-bit GIMP. Still, pretty effect results can be created using it. No preview though (also, I cheated a little in that I did some selective erase throughs on the last flower). :)
http://registry.gimp.org/node/25422
Uploaded with ImageShack.us
 Post subject: Re: Clone Layer tool.
PostPosted: Sun Jul 10, 2011 9:26 am  (#2)
very pretty Lyle....
PostPosted: Sun Jul 10, 2011 10:40 am  (#3)
Using gimp 2.7.3 portable, tried installing the 64-bit version and it says libgimp-2.0-0.dll is missing from my computer. Now where do I find that? It would have to be installed on the flash drive.
Found this but I don't know how to use the information. Gimp starts fine, just the plug-in is saying it is missing.
http://objectmix.com/graphics/138872-dll-files-not-found.html
I see the file on the flash drive in gimp-2.7.3 > bin
PostPosted: Sun Jul 10, 2011 12:06 pm  (#4)
Well duhhhh! I finally figured out how to install the plug-in on my flash drive in Win7. Just not used to the Windows stuff anymore.
Anyway, I copied the exe file into the portable gimp 2.7.3 plug-ins folder and it installed. Have restarted gimp 3 times now and no error messages. It doesn't show up in the Layer menu nor does it show up in the Layers window right-click menu.
PostPosted: Sun Jul 10, 2011 1:11 pm  (#5)
Oh, but which one is the last one...? :P
Looks nice
PostPosted: Sun Jul 10, 2011 1:42 pm  (#6)
I think I found the last one ;)
I'm back I think
PostPosted: Sun Jul 10, 2011 2:48 pm  (#7)
Doesn't take too much of an eye to see my botched result Amanda (but thanks for humoring me. ;) ). lol
Guess it's quite obvious eh Willy? lol
PostPosted: Sun Jul 10, 2011 3:59 pm  (#8)
I tried to compile this in windows 32 bit and got a pkgconfig error.Setting the correct path still produces the error.
I have gimptool-2.0 in Gimp-2.7.3 , and the path to pkgconfig in lib set, so i wonder what the problem is?
Hope sam can compile it for us poor 32 bit users. :)
PostPosted: Sun Jul 10, 2011 4:04 pm  (#9)
Looks like a nice idea that could be G'MICable one day. I keep the link :)
PostPosted: Sun Jul 10, 2011 4:27 pm  (#10)
Now that would be cool David; then we would have a version that has both preview and works with GIMP 2.6.x. :)
PostPosted: Sun Jul 10, 2011 4:30 pm  (#11)
Nice David thanks!
PostPosted: Wed Aug 03, 2011 11:20 am  (#12)
Hello Friends!
CloneLayer Tool has been updated to v0.2beta and ready to download!
Linux and windows (32/64) binary files are available!
Was added colorize, shadow, spread effects. Redesigned user interface. Fixed some bugs.
More about this plugin you can read at my blog - http://remyawm.blogspot.com/2011/07/clo ... lugin.html
best regards, Remy!
p.s.
see, video tutorial - "The Gears" @ http://www.youtube.com/watch?v=HmpRUu3ygZA
PostPosted: Wed Aug 03, 2011 5:14 pm  (#13)
Thanks for the 64-bit version Remy; it works great. :)
PostPosted: Thu Aug 04, 2011 7:58 am  (#14)
Yes it is an awesome addition to Gimp!
Thanks so much. :)
PostPosted: Wed Feb 15, 2012 1:24 pm  (#15)
does this work in 2.7.5? if so, which plugins folder is it to be placed under "lib" or "shared"....When I put it in shared plugins...it does not show up under "layer". when I place it in Lib plugins folder I keep getting an error at startup when loading plugins.
basically what I want to do....is apply an image and/or text to a rotating bullet in slow mo....
will this script accomplish this?
thanks...any help is greatly appreciated...
PostPosted: Wed Feb 15, 2012 2:05 pm  (#16)
Yes it is for Gimp-2.7 versions interface only. :)
It needs to go into your gimp-2.7/plug-ins folder. :)
Usually that is under your userfolder directory.For instance mine (for Windows), is here.
C:\Documents and Settings\Rod\.gimp-2.7\plug-ins
Once installed you will find it under the Layers menu.
PostPosted: Wed Feb 15, 2012 3:45 pm  (#17)
so you're saying this works with 2.7 only or 2.7.x?.....where to place file in the portable version? I do have a .gimp-2.7 folder within this folder(portable) on my desktop and a plugins folder within that..where I placed this file but I still get the error that the plugin failed to start.
update...
nevermind....I dl'd from partha the regular gimp 64bit and installed and it showed up...
PostPosted: Wed Feb 15, 2012 7:20 pm  (#18)
Glad to hear you got it working. :)
PostPosted: Thu Oct 02, 2014 11:38 am  (#19)
testing rotation with animation
PostPosted: Fri Oct 03, 2014 8:20 am  (#20)
The clone layer tool is a fantastic plug-in. :)
