I've been obsessed with Truchet style images lately, both creating tiles and writing scripts to automate combinations of tiles, a few of the results are shown in the gifs below
If anyone wishes to give it a try I've placed a script and an xcf file in the zipped folder above
It works with my gimp version 2.10.36 portable, running python 3.12.1 on windows 10
If you wish to try the script
Extract the two files from the zipped folder, place the simple-patterns script in your plug-ins folder then open the tile-patterns.xcf file in gimp
The script can be found at <Image>/Filters/Python-fu/Simple patterns truchet style
When the script is run it utilises visible layers from the source image, and will rotate and flip at random if selected to do so
It would be easy to create your own designs, just add a new layer, create your pattern and ensure it is set visible
If you create your tiles from scratch please note, the script only works on Square images of type RGB
'RE: the "Singles, Pairs, Triplets, etc" option.
If set to 0 (default): The script creates and fills 1 layer with tiles selected at random from the visible layers in the source image
If set to 1: The script creates 1 layer for each visible layer in the source image and fills the layer from its counterpart in the source image
If set to 2 (pairs): The script creates enough layers to make every possible pair combination from the visible layers in the source image
If set to 3 (triplets): The script creates enough layers to make every possible triplet combination from the visible layers in the source image
And so on
Thanks for looking, steve
PS
If you were to set all 12 layers visible in the xcf and set "Singles, Pairs, Triplets, etc" to 2 it will create 66 layers (all possible tile pair combinations), set to 3 it will create 220 layers (tile triplets), set to 4 it will create 495 layers, set to 5, well...... it starts getting silly
