It is currently Mon Nov 23, 2026 1:01 pm
 Post subject: Plugin
PostPosted: Mon Mar 24, 2025 10:32 am  (#1)
I'm looking for a plugin. I'm using Windows 10. Unfortunately, when I deleted the program, I forgot to save it. I use Google Translate.
 Post subject: Re: Plugin
PostPosted: Mon Mar 24, 2025 2:06 pm  (#2)
Are you wanting to make the background pattern? The pattern behind the fox image?
PostPosted: Mon Mar 24, 2025 2:23 pm  (#3)
I'm looking for a plugin that can create an image like this. It uses the colors of the image to create a background. Unfortunately, I didn't save it.
PostPosted: Mon Mar 24, 2025 5:27 pm  (#4)
Hi baboca
viewtopic.php?f=9&t=15291&p=295566#p295566
PostPosted: Tue Mar 25, 2025 12:47 am  (#5)
Thank you, I was looking for this!!!
