It is currently Tue Nov 17, 2026 4:17 pm
 Post subject: GEGL Frozen Gel Text plugin
PostPosted: Tue Mar 25, 2025 1:36 pm  (#1)
Update, plugin is released. Download here
https://github.com/LinuxBeaver/GIMP-GEG ... l/releases
Here are previews of the effect in GEGL syntax, is anyone interested in me turning this into a easy to use plugin? Also it will have alternative colors other then light blue and will be non-destructive in GIMP 3.
 Post subject: Re: Plugin idea - GEGL Frozen gel Text - Should I make this plugin?
PostPosted: Tue Mar 25, 2025 4:20 pm  (#2)
Absolutely! :tyspin
PostPosted: Tue Mar 25, 2025 9:10 pm  (#3)
Thanks Adm,
I haven't even started yet but here is an example of the hypothetical plugin in an alternative color then sky blue
PostPosted: Wed Mar 26, 2025 5:08 am  (#4)
It would be a great additional effect for Gimp-3.0 Beaver. Thanks.
I thought you were finished creating new GEGL plugins? Happy to see you are not done yet. :)
PostPosted: Wed Mar 26, 2025 11:27 pm  (#5)
I converted the GEGL syntax to the best of my ability to node connections in a .c file and this is how it turned out
YUCKY! I made a mistake somewhere in the graph and don't know how to fix this, I'm stuck on a technical problem.
I hope it gets solved soon, currently I have no idea what is wrong and I spend 10-15 minutes debugging
PostPosted: Wed Mar 26, 2025 11:53 pm  (#6)
I got it working. Two major problems caused that bug above, both were solved. Now I just have to make final tweaks before releasing frozen gel.
The plugin should be released some time later today
PostPosted: Thu Mar 27, 2025 1:07 am  (#7)
I assume the plugin is done but I might make more modifications, Here is the source code to compile it. Later today I will post binaries.
This will only work on GIMP 3 or versions of GIMP 2.10 that use GEGL 4.50+, this is because it depends on native filter gegl:bevel that GEGL 0.4.48 does not have.
SourceCode_of_frozen_gel.zip [14.14 KiB]
Downloaded 118 times
PostPosted: Thu Mar 27, 2025 2:38 am  (#8)
Looks good! :)
 Post subject: Re: GEGL Frozen Gel Text plugin (releasing soon)
PostPosted: Thu Mar 27, 2025 6:58 am  (#9)
Thanks for the new filter.
It will be very popular in winter :)
PostPosted: Thu Mar 27, 2025 1:14 pm  (#10)
I have not made any changes since viewtopic.php?f=9&t=21596#p295629 , however, This plugin though on the verge of release is still not publicly released and I was thinking about changing the name from "Frozen Gel" to simply "Ice Text" and operation name from lb:frozen-gel to lb:icetext or whatever. If I change the operation name all presets and NDE filters for the source compile build users will break
I'm thinking about what to do. It might release any second it might release another day or two.
PostPosted: Thu Mar 27, 2025 1:56 pm  (#11)
Plugin is released. No changes have been made since last night; which means the source code is exactly the same.
https://github.com/LinuxBeaver/GIMP-GEG ... Frozen_Gel
*note white text is a custom configuration
windows_binaries_gegl_plugin_frozen_gel.zip [100.05 KiB]
Downloaded 145 times
linux_binaries_gegl_plugin_frozen_gel.zip [22.88 KiB]
Downloaded 128 times
Location to put binaries
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
PostPosted: Sat Mar 21, 2026 10:01 pm  (#12)
Linux is the same so we aren't going to bother hosting its binaries as duplicates, but Windows updated due to GIMP 3.0.8+ needing gettext
Source code is above in this thread.
frozen_gel_windows_binaries_gegl_plugin.zip [2.11 MiB]
Downloaded 78 times
