It is currently Tue Nov 17, 2026 4:40 pm
 Post subject: GEGL Engrave
PostPosted: Wed Apr 16, 2025 11:15 pm  (#1)
Yes, this plugin is inspired by rafferty's work but I wrote mine from scratch.
New Plugin GEGL Engrave
https://github.com/LinuxBeaver/GEGL-GIMP-PLUGIN_Engrave
This plugin was made a few hours ago. GEGL does a pseudo engraving effect
Look for it in filters>artistic>engrave or search for engrave, (it shares the name of an existing plugin) I know
Download
linux_binaries_gegl_plugin.zip [7.53 KiB]
Downloaded 209 times
SourceCode.zip [4.75 KiB]
Downloaded 217 times
windows_binaries_gegl_plugin.zip [33.09 KiB]
Downloaded 234 times
Location to put binaries
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
Final pic
Also this is obvious but for newcomers who don't know the plugin is non-destructive/re-editable in GIMP 3. Feel free to share feed back about the plugin :clap :tyspin
 Post subject: Re: GEGL Engrave
PostPosted: Wed Apr 16, 2025 11:25 pm  (#2)
It has a color change mode my previous previews never showed off
PostPosted: Thu Apr 17, 2025 4:54 am  (#3)
I really like this plugin - for me it's the best in the Engrave category. It allows for many combinations of parameters, not to mention playing with the layer mode.
PostPosted: Thu Apr 17, 2025 8:06 pm  (#4)
Unfortunately, it doesn't work for me in Gimp-2.10.38-1.
Gimp displays a strange message:
and stops loading.
Strange message - because GimpGegl-gegl-engrave works:
PostPosted: Thu Apr 17, 2025 8:16 pm  (#5)
and stops loading.
Thank you for telling me this. I haven't yet shipped it with my Github page's source code/all binaries update. So I can fix it.
I can not reproduce on GIMP 2.10.38 On Linux. Both work fine for me.
PostPosted: Thu Apr 17, 2025 8:26 pm  (#6)
I think I fixed it. Tell me if the problem persist on 2.10.38 on Windows. the plugin was renamed from "Engrave" to "Engrave Image"
MareroQ, please tell me if it resolves on 2.10.38
PostPosted: Thu Apr 17, 2025 9:00 pm  (#7)
Unfortunately not. :(
PostPosted: Thu Apr 17, 2025 9:07 pm  (#8)
damn, its the name of the source code file. "engrave.c" It will be fixed by renaming it to "engraver.c" This should fix it.
If GIMP 2.10.40 ever releases my inner glow plugin will break for the same reason, its source code file will need to be renamed from "inner-glow.c" to something else. This is because the official filter uses the same name.
PostPosted: Thu Apr 17, 2025 9:34 pm  (#9)
Now there is no message but the plugin does not register in the menu.
PostPosted: Thu Apr 17, 2025 9:39 pm  (#10)
Can it run if you look in the GEGL operation dropdown list for "engrave"?
PostPosted: Thu Apr 17, 2025 9:43 pm  (#11)
Try this, last attempt.
The title was renamed as well
PostPosted: Thu Apr 17, 2025 9:49 pm  (#12)
Lastly if that doesn't work try deleting "GimpGegl-lb-engrave-config.settings" from `/.config/GIMP/2.10/filters`
PostPosted: Thu Apr 17, 2025 9:51 pm  (#13)
Unfortunately - still no registration in the menu.
PostPosted: Thu Apr 17, 2025 9:57 pm  (#14)
off topic comment retracted
PostPosted: Thu Apr 17, 2025 10:05 pm  (#15)
Please look in GEGL Operation>Engrave Image to find it
PostPosted: Thu Apr 17, 2025 10:12 pm  (#16)
No plugin of mine in GIMP 2.10 is registered in the main menu. Its all in the "GEGL Operation" drop down list area. Haven't you remembered that filters in the main menu are GIMP 3 exclusive?
PostPosted: Thu Apr 17, 2025 10:42 pm  (#17)
"Engrave Image" in Gimp 2.10 registers in Gegl Operation (and works), but not in Menu (Yes, I am forgetful) and Search Actions.
PostPosted: Fri Apr 18, 2025 2:38 pm  (#18)
I just updated Engrave's binaries and code so it doesn't crash GIMP 2.10
PostPosted: Fri Apr 18, 2025 10:32 pm  (#19)
Look how Engrave blends with Royal on the linear burn and other blend modes
https://github.com/LinuxBeaver/GEGL-GIMP-PLUGIN_Royal
PostPosted: Mon Jun 23, 2025 8:45 pm  (#20)
Engrave updated and the update will not break presets but it may change appearances if used as non-destructive in GIMP 3. This is because GIMP 3 will reload the newer gegl syntax of the plugin
Preview of the improved newsprint dot slider
Changes made
1. The newsprint dots are much more visible (before they were barely visible)
2. Newsprint slider doesn't remove the color overlay (before it use to)
3. The line size still goes up to 25 something but the GUI doesn't display beyond 6. Still one can manually move the slider to 25 if they want and presets above 6 will load.
Once again if you have a GIMP 3 .xcf file with GEGL Engrave it may look different such as dots and possibly colors if you changed the color and moved up the newsprint slider, but it will still load normal. This is the way engrave was always suppose to be and if I had known back in April I would have corrected it then.
engrave_linux_binaries_gegl_plugin.zip [7.55 KiB]
Downloaded 64 times
engrave_windows_binaries_gegl_plugin.zip [33.13 KiB]
Downloaded 73 times
engrave_SourceCode.zip [4.76 KiB]
Downloaded 64 times
LOCATION TO PUT BINARIES
Windows
Linux
