It is currently Mon Nov 23, 2026 3:25 am
 Post subject: Please test if these two plugins launch on GIMP 3.0.2 on Windows 10/11
PostPosted: Thu Apr 17, 2025 10:25 pm  (#1)
These plugins are meant to be used with GIMP blend modes, can someone test if they launch in GIMP 3.0.2 on Windows?
Bevel (to blend)
Inner Glow (to blend)
bevel_and_innerglow.zip [67.23 KiB]
Downloaded 73 times
Location to put binaries
**Windows**
then restart GIMP 3.0.2 and search for "(to blend)" to find them or go to filters>text styling and manually look. if they work can someone please tell me that they launched successfully? Thanks
 Post subject: Re: Please test if these two plugins launch on GIMP 3.0.2 on Windows 1
PostPosted: Thu Apr 17, 2025 10:38 pm  (#2)
Bevel (for blending) and Inner Glow (for blending) registered in Gimp-2.10 and Gimp 3. (without downloading new files).
In Gimp3 only Bevel (for blending).
You beat my answer. :geek
PostPosted: Thu Apr 17, 2025 10:41 pm  (#3)
So you cannot find Inner Glow (to blend) in GIMP 3?
PostPosted: Thu Apr 17, 2025 10:53 pm  (#4)
So neither bevel (to blend) nor inner glow (to blend) works on Windows 11 GIMP 3.0.2
Try this Inner Glow
PostPosted: Thu Apr 17, 2025 11:02 pm  (#5)
It's strange that older versions work in Win10.
Do you recommend replacing them?
PostPosted: Thu Apr 17, 2025 11:04 pm  (#6)
What old versions work? are they gegl:bevel or lb:bevel?
PostPosted: Thu Apr 17, 2025 11:13 pm  (#7)
Older than those posted here but the newest from:
viewtopic.php?f=9&t=21452&p=295902#p295902
PostPosted: Thu Apr 17, 2025 11:14 pm  (#8)
They are 99% the same. Has Inner Glow original worked at all
PostPosted: Thu Apr 17, 2025 11:23 pm  (#9)
I have to install 40 gigabytes on Windows 10 on my machine just to figure out this problem. I'm backing up content on a thumbdrive to make room for diskspace for Windows 10 and GIMP 3.0.2 on Windows 10
PostPosted: Fri Apr 18, 2025 1:19 am  (#10)
On my windows 10 virtual box everything is working fine for me, both innerglow (to blend) and bevel (to blend)
I tested binaries from the latest code which is here.
https://github.com/LinuxBeaver/LinuxBea ... lugins.zip
PostPosted: Fri Apr 18, 2025 2:18 am  (#11)
Beaver both bevel and innerglow to blend work fine for me in Gimp-3.0.3 in Windows 10.
