It is currently Tue Nov 17, 2026 4:17 pm
 Post subject: Use GEGL graph filter non-destructively in GIMP 3
PostPosted: Sat Apr 19, 2025 1:23 am  (#1)
In GIMP 3 the filter GEGL Graph cannot be used non-destructively or applied on layer groups. It always forces a merge. But there is a work around. I made a plugin called port:gegl that is exactly GEGL graph but with the word "port" in front of it. It works non-destructive and on layer groups.
Its just a fork of GEGL graph renamed.
gegl_graph_non_destructive_source_code.zip [4.44 KiB]
Downloaded 61 times
linux_binaries_gegl_plugin.zip [6.62 KiB]
Downloaded 73 times
windows_binaries_gegl_plugin.zip [32.27 KiB]
Downloaded 69 times
LOCATION TO PUT BINARY
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
So if you want to learn GEGL syntax consider using this. Notice how in the image I write GEGL syntax to make a sepia effect.
 Post subject: Re: Use GEGL graph filter non-destructively in GIMP 3
PostPosted: Sat Apr 19, 2025 1:25 am  (#2)
This plugin is also found here, but it is not part of my 105+ plugin collection. As I did not make this filter, it is simply nothing more a rename of an existing filter.
https://github.com/LinuxBeaver/GEGL-GIM ... P_filters/
PostPosted: Sat Mar 21, 2026 1:27 pm  (#3)
This plugin can be downloaded for Windows here, where it coships with six others. Look for geglport.dll
download/file.php?id=82451
the source code is above and or at
https://github.com/GNOME/gegl/
PostPosted: Sat Mar 21, 2026 2:31 pm  (#4)
Thank you contrast_!
For your continuing contributions to GEGL and to Gimp Chat.
:jumpclap :clap :jumpclap
