It is currently Mon Nov 23, 2026 2:36 am
 Post subject: GEGL Tile Image (with Zoom and rotation)
PostPosted: Sun Apr 20, 2025 2:10 pm  (#1)
New Plugin that tiles images and also allows the user to rotates and zoom out.
note: Plugin goes very slow. Let me know if it has any issues and feel free to talk about it in this thread.
Download here
tile_windows_binaries_gegl_plugin.zip [32.08 KiB]
Downloaded 101 times
tile_linux_binaries_gegl_plugin.zip [6.49 KiB]
Downloaded 88 times
tile_SourceCode.zip [4.7 KiB]
Downloaded 278 times
You will find the plugin in Filters>Map>Tile and Zoom
LOCATION TO PUT BINARIES
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
 Post subject: Re: GEGL Tile Image (with Zoom and rotation)
PostPosted: Sun Apr 20, 2025 3:52 pm  (#2)
It just updated to fix a mini bug, which results in some non-destructive presets breaking. But thats ok because the plugin is only like 1 hour old and only has one download
PostPosted: Mon Apr 21, 2025 11:18 am  (#3)
Just a suggestion about the tiles.
Maybe you could program some of this:
viewtopic.php?f=9&t=17577&p=241345&hilit=Symmetry+Tile#p241345
into a GEGL filter?
PostPosted: Mon Apr 21, 2025 1:12 pm  (#4)
into a GEGL filter?
There is a native filter that does something like this, its called Kalidescope (gegl:mirrors)
PostPosted: Mon Apr 21, 2025 8:52 pm  (#5)
The Kaleidoscope filter does not manipulate tiles. :roll:
