It is currently Tue Nov 17, 2026 4:56 pm
 Post subject: GEGL Heavenly Light Rays
PostPosted: Sun Apr 20, 2025 11:13 pm  (#1)
Filter is located in Filters>Render>Fun. Use in default for easy use, or disable the checkbox and set a blend mode manually such as linear light. Its also smart to use the master opacity slider that all GEGL filters have.
DOWNLOAD
windows_binaries_gegl_plugin.zip [33.09 KiB]
Downloaded 1706 times
linux_binaries_gegl_plugin.zip [7.4 KiB]
Downloaded 1685 times
SourceCode.zip [4.69 KiB]
Downloaded 1704 times
LOCATION TO PUT BINARIES
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
Once again Filters>Render>Fun>Heavenly Rays
 Post subject: Re: GEGL Heavenly Light Rays
PostPosted: Sat Mar 21, 2026 1:22 pm  (#2)
Working Plugin for Windows GIMP 3.2 and 3.0.8 and hopefully beyond
heaven_windows_binaries_gegl_plugin.zip [37.53 KiB]
Downloaded 29 times
Source Code for Linux and all other instructions are provided above
To compile on Windows you need the gettext environment provided here
https://github.com/LinuxBeaver/LinuxBea ... lugins.zip
LOCATION TO PUT GEGL PLUGIN BINARIES
Windows
