Hello,
You are welcome to own the latest version of Roller. Roller's main purpose is make an image composition, such as a wallpaper.
It's designed to:
· follow a step-by-step creative process.
· make a rendered image reproducible over different sessions.
· have workflow memory.
· hide complexity.
· be sensitive to backwards change in the step-by-step creative process.
From Roller's Change LogQuote:
Roller 7 (August 26, 2025)
Made comprehensive changes to large sections of code. Roller 7 Preset is not compatible with previous Roller Preset.
Added
· Heat/Preset.
· two options to Accent/Wave Fill: Type and Horizontal.
· a Frame called Net.
· a contrast option to Mod.
· a Noise/Type/Drip option.
· Add sub-types, Color and Inset.
· Gradient options to Accent/Fading Maze.
· Switches to the sub-Shadow groups.
· a Sort button to the Light/Heat dialog.
· a Mean Color option to Accent/Color Grid.
· to Accent/Back Game, a Mean Color and a Horizontal option.
· a Clip option to Fringe.
· a Method option to Line.
· a Neatness option to Frame/Ceramic.
Changed
· the Preset file format to 'json'.
· The automated Last Used file storage is now limited to the Steps Preset.
· Accents Back Game, Color Grid, and Gradient Fill, simplifying them.
· Netting (now Grid) output now has mirrored symmetry when it fills a selection.
· Frame/Brushy layers now share the same emboss settings.
· Inner Shadow output for overlapping frames. The Inner Shadow is now created solely from the overlapping Frame/Wrap layer.
Tweaked
· Noise/Ink.
· Accent/Lost Maze.
· Frame/Tape.
Fixed
· a garbled Steps list when Model sorting with the Move Up and Move Down buttons.
· a few problems with Heat/Remove processing.
· Accent/Cube Pattern's height scale was over its maximum size which would break its pattern.
· Image/Resize/Crop had a few problems.
· a few problems with Specimen Speckle not working as intended.
· Fringe would clip brush-stroke output in unintended ways.
· a Brush-stroke closed-loop which had a tangent problem with its last paintbrush.
· Brush-stroke would skip its last paintbrush.
· Frame/Over had some problems with image assignment.
Moved
· Backdrop/Backdrop Style to its own step, Accent.
· Moved Netting options to a Grid dialog.
· Frame/Emboss option to a dialog button.
Removed
· Accent/Image Gradient.
· Accent/Core Design.
Renamed
· Backdrop to Background.
· Backdrop Style to Accent.
· Gradient Light to Light.
· deco/Netting to Grid.
· Mask/Cut-out to Invert.
· Trailing Vine to Trail Vine.
· Mystery Grate to Grate Mystery.
Roller's main windowAttachment:
File comment: The Global option group is the first step in the navigation tree.
Roller 7Attachment:
File comment: Fix and improve the previous version. Include 22 preset for user inspection.
Roller 7.0.0 (GimpChat).zip [1.71 MiB]
Downloaded 89 times
Additional FramesAttachment:
File comment: Separated from the main zip due to its file size.
Roller 7.0.0 - Additional Frame.zip [4.2 MiB]
Downloaded 82 times
Please continue scrolling through this topic to view some Roller 7 output made from the included presets.
