It is currently Sun Nov 22, 2026 4:01 am
 Post subject: Custom Font Paragrapher v2.5b for Gimp 2.10 Update
PostPosted: Thu Sep 11, 2025 9:34 am  (#1)
Custom_Font_Paragrapher_v2_5b_Tabbed.zip [21.26 KiB]
Downloaded 53 times
Download, unzip and copy to your Gimp 2.10 plug-ins folder.
The filter can be located via:
Filters>>Custom Fonts>>Using Tools>>Custom Font Paragrapher v2.5b Tabbed...
This update adds another item to the alternative character options on Tab 1 of the filter dialog.
The option can be used with single case custom fonts that have a set of alternative characters.
The examples below show a set of lower-case characters with alternative characters in a broader weight...
Without the option:
With the option:
The next examples show an uppercase custom font that use both colour and shape alternatives.
Without the option set:
And with the option:
 Post subject: Re: Custom Font Paragrapher v2.5b for Gimp 2.10 Update
PostPosted: Sun Sep 14, 2025 4:03 pm  (#2)
Thanks Skinnyhouse for the update. :)
