It is currently Wed Nov 18, 2026 10:46 pm
 Post subject: Custom Font Ghoster Update to v0.4 for Gimp 2.10
PostPosted: Tue Nov 11, 2025 5:49 am  (#1)
This update fixes the issue identified by Issabella and problems encountered when using with thin character layers.
It also adds an option to add ghost characters above and below the original character.
Personally I think this works better when the character is in front of the ghosts but if you use the other option I would suggest lowering the opacity of the ghost layers.
Custom_Font_Ghoster_v0_4.zip [4.86 KiB]
Downloaded 57 times
Download, unzip and place in your Gimp 2.10 user plug-in folder.
Examples of the new option:
Ordering behind:
Ordering in front:
 Post subject: Re: Custom Font Ghoster Update to v0.4 for Gimp 2.10
PostPosted: Thu Nov 13, 2025 2:50 am  (#2)
Thanks Skinnyhouse! :)
