It is currently Wed Nov 18, 2026 7:07 pm
 Post subject: problem solving thread (ignore)
PostPosted: Sun Feb 01, 2026 7:50 am  (#1)
I tried to fix it but failed
My adding
intl_dep = dependency('intl', static : true, required : false)
and
dependencies : [gegl, intl_dep],
to each plugins meson.build file.
failed to make them work in default on Windows
It still shows
libgegl-0.4-0.dll => not found
libglib-2.0-0.dll => not found
libgobject-2.0-0.dll => not found
libintl-8.dll => not found
KERNEL32.dll => C:\windows\system32\KERNEL32.dll (0x00000000007f0000)
kernelbase.dll => C:\windows\system32\kernelbase.dll (0x0000000001a20000)
ntdll.dll => C:\windows\system32\ntdll.dll (0x0000000002120000)
msvcrt.dll => C:\windows\system32\msvcrt.dll (0x0000000001a20000)
and libintl-8.dll is the problem
source_code_of_all_GEGL_plugins.zip [1.91 MiB]
Downloaded 81 times
WindowsBinaries.zip [4.62 MiB]
Downloaded 92 times
LinuxBinaries.zip [1.16 MiB]
Downloaded 86 times
Location to put Binaries
Windows (may need to create "plug-ins" folder if it doesn't exist.)
C:\Users\USERNAME\AppData\Local\gegl-0.4\plug-ins
Linux
Linux (Flatpak) includes ChromeBook
Grok and I are working on solving the problem
 Post subject: Re: GEGL plugins for GIMP 3.0.6 and 3.2 Windows that work in default
PostPosted: Sun Feb 01, 2026 7:51 am  (#2)
none of the plugins updated but EVERY MESON FILE did which compiles them
PostPosted: Sun Feb 01, 2026 9:23 am  (#3)
Instal new in WindowsBinaries.zip [4,62 MiB] GIMP 3.2,0-RC2
Plug-ins do not appear, MareroQ method works
