It is currently Fri Nov 13, 2026 6:21 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: Custom Font Wibbler Update to v0.1g Tabbed for Gimp 2.10
PostPosted: Sun Feb 22, 2026 3:32 am  (#1)
This update addresses a number of issues that surfaced when using Wibbler with non-custom font paths:
Escaping fills with shrinking selections
Blur not applied to first layer with multiple paths
There are no changes to the filter dialog and the existing help guides still apply.
Download, unzip and install to your user plug-ins folder in Gimp 2.10.
Menu: Filters>>Custom Fonts>>Constructing Tools>>Custom Font Wibbler 0.1g Tabbed...
Custom_Font_Path_Wibbler_v01g_Tabbed.7z [17.4 KiB]
Downloaded 388 times
Simple example:
And with a touch of 3dness
 Post subject: Re: Custom Font Wibbler Update to v0.1g Tabbed for Gimp 2.10
PostPosted: Sun Feb 22, 2026 12:35 pm  (#2)
A slightly more involved example:
The paths:
FujiPaths.xcf [8.77 KiB]
Downloaded 372 times
PostPosted: Sun Feb 22, 2026 2:03 pm  (#3)
Thanks Skinnyhouse for your help. I used your nice creation to practice.
It's really nice to use your Wibbler. :clap
PostPosted: Mon Feb 23, 2026 12:52 am  (#4)
Thanks for the new update Skinnyhouse! :)
PostPosted: Mon Feb 23, 2026 11:48 am  (#5)
You're welcome Rod.
Issa: You look as if you are feeling more confortable with the Wibbler options.
Another practise example (taking inspiration from a recent image on DeviantArt).
Flowerhead_paths.xcf [8.58 KiB]
Downloaded 365 times
The line path that radiates out to the edge of the petals was not removed from the image but copied and rotated for each curve of the petal before applying the filter.
PostPosted: Mon Feb 23, 2026 11:54 am  (#6)
If anyone is struggling with the path tool or needs a few paths for practising with the filter here are a couple of files containing very simple shape paths made with only two or three anchor points.
TwoAnchor-Shapes.xcf [6.76 KiB]
Downloaded 371 times
ThreeAnchor-Shapes.xcf [7.14 KiB]
Downloaded 366 times
PostPosted: Tue Feb 24, 2026 7:19 am  (#7)
And another to practise?
StreetPaths.xcf [11.4 KiB]
Downloaded 347 times
Example outcome...
PostPosted: Tue Feb 24, 2026 11:34 am  (#8)
Even though you make it super easy, I'm going really slowly.
But I feel better to see that I'm not as lost as before. :)
Thank you so much.
PostPosted: Wed Feb 25, 2026 5:24 am  (#9)
My first illustration by myself and enjoying a lot.
Thanks Skinnyhouse. :jumpclap
PostPosted: Wed Feb 25, 2026 8:03 am  (#10)
Really clever Issabella - I like the heart brush touch too.
At first I thought your street was my original one until I scrolled up.
I think you have got the hang of it now.
:kpix :bigthup
PostPosted: Wed Feb 25, 2026 8:06 am  (#11)
Another to have a go at...
SardinePaths.xcf [10.82 KiB]
Downloaded 362 times
PostPosted: Thu Feb 26, 2026 3:13 am  (#12)
Another flower head...
Flowerhead2_paths.xcf [1.48 MiB]
Downloaded 414 times
PostPosted: Thu Feb 26, 2026 4:47 am  (#13)
:kpix :bigthup
Thanks a lot.
Sardine creation is great!
I like to have your Wibbler because the outcomes are always very nice and attractive. :hi5
PostPosted: Thu Feb 26, 2026 12:13 pm  (#14)
More fish :)
PostPosted: Sun Mar 01, 2026 10:13 am  (#15)
Oooooo nice fishies Issa.
Here is a set of wave-like paths that may be useful for testing/playing with brushes and brush options (particularly spacing). Use Apply filter to All paths with no fill on the 3rd dialog tab.
WavesPaths.xcf [1.91 MiB]
Downloaded 401 times
Example outcome:
PostPosted: Mon Mar 02, 2026 3:51 am  (#16)
Making the exercises. I think I am being a bit better. Thank you Skinnyhouse. :tyspin
PostPosted: Mon Mar 02, 2026 6:52 am  (#17)
A good opportunity to play with all the brushes that we collect - and on reflection I do feel that the brush spacing is the key to getting a good result.
PostPosted: Wed Mar 04, 2026 3:09 am  (#18)
With Wibbler the images have a nice charm. Thanks Skinnyhouse.
I used a beautiful frame made by TeaMouse. Thanks you too.
PostPosted: Wed Mar 04, 2026 3:18 am  (#19)
Nice Issa; a perfect match of frame and image. :bigthup
A set of paths that could be used to practise the reduce fill option...
Range of values use biggest to smallest objects:
wibble factor: 20 to 2
reduce fill: 4 to 1
FishesInDishes.xcf [9.5 KiB]
Downloaded 357 times
PostPosted: Wed Mar 04, 2026 4:33 am  (#20)
:clap :tyspin
