| GimpChat Member |
The plugin is 99% done. Compile this yourself and you can use it early.  /* This file is an image processing operation for GEGL * * GEGL is free software; you can redistribute it and/or * modify it under the terms of the GNU Lesser General Public * License as published by the Free Software Foundation; either * version 3 of the License, or (at your option) any later version. * * GEGL is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU * Lesser General Public License for more details. * * You should have received a copy of the GNU Lesser General Public * License along with GEGL; if not, see <https://www.gnu.org/licenses/>. * * Credit to Øyvind Kolås (pippin) for major GEGL contributions * 2026, beaver, Bubble text
requires lb:glassovertext (which it ships with)
start of syntax
gaussian-blur std-dev-x=1 std-dev-y=1 abyss-policy=none clip-extent=false id=0 color-overlay value=white
cubism tile-size=2.0 seed=3423 gaussian-blur std-dev-x=2 std-dev-y=2 abyss-policy=none
median-blur radius=2 alpha-percentile=70 abyss-policy=none color-overlay value=#98e1ff bevel type=bump blendmode=multiply radius=8 elevation=44 depth=11 edge gray
color-to-alpha color=black gaussian-blur std-dev-x=1 std-dev-y=1 abyss-policy=none clip-extent=false id=y
dst-over aux=[ ref=y gaussian-blur std-dev-x=7 std-dev-y=7 abyss-policy=none clip-extent=false opacity value=0.11 ] dst-over aux=[ ref=y color-overlay value=black gaussian-blur std-dev-x=2 std-dev-y=2 abyss-policy=none clip-extent=false opacity value=1.1 ]
id=gm gimp:layer-mode layer-mode=grain-merge blend-space=rgb-linear opacity=0.45 aux=[ ref=gm alien-map color-model=rgb cpn-1-frequency=3.641 cpn-2-frequency=2.9489999999999998 cpn-3-frequency=7.5529999732971191 cpn-1-phaseshift=0 cpn-2-phaseshift=0 cpn-3-phaseshift=0 cpn-1-keep=no cpn-2-keep=no cpn-3-keep=no ]
noise-reduction iterations=4
over aux=[ ref=0 lb:glassovertext azimuth=94 hyperopacity=0.3 ] dst-over aux=[ ref=0 color-overlay value=#0c82bb gaussian-blur std-dev-x=7 std-dev-y=7 abyss-policy=none clip-extent=false opacity value=0.78 ]
end of syntax */
#include "config.h" #include <glib/gi18n-lib.h>
#ifdef GEGL_PROPERTIES
/*Properties go here*/
enum_start (puff_puffpuff322928) enum_value (GEGL_BEVEL_HIGHPUFF, "highpuff", N_("High Puff")) enum_value (GEGL_BEVEL_LOWPUFF, "lowpuff", N_("Low Puff")) enum_value (GEGL_BEVEL_LOWPUFF2, "lowpuff2", N_("Low Puff 2")) enum_end (puffpuffpuff322928)
property_enum (puffblend, _("Internal Blend/Puff"), puffpuffpuff322928, puff_puffpuff322928, GEGL_BEVEL_LOWPUFF2) description (_("There is no such thing as a perfect bubble text, only trade offs and options that are convenient in some places and bad in others. So try different internal bevel blend modes to have more or less puff"))
property_double (base_blur, _("Base blur"), 2.0) value_range (0.0, 4.0) ui_range (0.0, 4.0) ui_gamma (1.5) description (_("Blur at the start of the graph to enhance the bubble")) ui_steps (0.5, 0.50)
property_double (tile_size, _("Base distortion"), 2.5) description (_("Base distortion of the bubble")) value_range (2.5, 4.0) ui_meta ("unit", "pixel-distance")
property_seed (seed, _("Base distortion seed"), rand) description (_("Seed of the base distortion"))
property_double (grow, _("Grow"), 70.0) value_range (60.0, 100.0) ui_range (1.0, 8.0) ui_gamma (1.5) description (_("Grow radius of the bubble")) ui_steps (0.5, 0.50)
property_double (elevation, _("Elevation"), 44.0) value_range (40.0, 60.0) ui_range (40.0, 60.0) ui_gamma (1.5) description (_("Elevation of the internal bump bevel")) ui_steps (0.5, 0.50)
property_double (azimuth, _("Azimuth"), 94.0) description (_("Light angle (degrees)")) value_range (0, 360) ui_meta ("unit", "degree") ui_meta ("direction", "ccw") ui_steps (0.5, 0.50)
property_double (cpn_1_frequency, _("Thin film control 1"), 3.6) value_range (3.0, 4.0) description (_("To modify the bubble's pseudo thin film interference iridescent properties"))
property_double (cpn_2_frequency, _("Thin film control 2"), 4) value_range (2, 4) description (_("To modify the bubble's pseudo thin film interference iridescent properties"))
property_double (cpn_3_frequency, _("Thin film control 3"), 7.5) value_range (7.0, 8.0) description (_("To modify the bubble's pseudo thin film interference iridescent properties"))
property_double (bg_opacity, _("Background opacity"), 0.78) value_range (0.0, 1.0) ui_range (0.0, 1.0) ui_gamma (1.5) description (_("Background opacity")) ui_steps (0.5, 0.50)
#else
#define GEGL_OP_META #define GEGL_OP_NAME bubblebuddy #define GEGL_OP_C_SOURCE bubblebuddy.c
#include "gegl-op.h"
/*starred nodes go inside typedef struct */
typedef struct { GeglNode *input; GeglNode *gaussian1; GeglNode *gaussian2; GeglNode *gaussian3; GeglNode *makewhite; GeglNode *coloroverlay1; GeglNode *coloroverlay2; GeglNode *cubism; GeglNode *median; GeglNode *bevellow; GeglNode *bevellow2; GeglNode *bevelhigh; GeglNode *edge; GeglNode *gray; GeglNode *normal; GeglNode *glass; GeglNode *nr; GeglNode *behind; GeglNode *behind2; GeglNode *alienmap; GeglNode *grainmerge; GeglNode *nopy; GeglNode *nopgm; GeglNode *nopconform; GeglNode *nop0; GeglNode *graphcapture; GeglNode *output; }State;
static void attach (GeglOperation *operation) { GeglNode *gegl = operation->node; GeglProperties *o = GEGL_PROPERTIES (operation); GeglColor *white = gegl_color_new ("#ffffff"); GeglColor *secondcolor = gegl_color_new ("#98e1ff"); GeglColor *thirdcolor = gegl_color_new ("#0c82bb");
State *state = o->user_data = g_malloc0 (sizeof (State));
/*new child node list is here, this is where starred nodes get defined
state->newchildname = gegl_node_new_child (gegl, "operation", "lb:name", NULL);*/ state->input = gegl_node_get_input_proxy (gegl, "input"); state->output = gegl_node_get_output_proxy (gegl, "output");
#define largepart \ " edge gray color-to-alpha color=black gaussian-blur std-dev-x=1 std-dev-y=1 abyss-policy=none clip-extent=false id=y dst-over aux=[ ref=y gaussian-blur std-dev-x=7 std-dev-y=7 abyss-policy=none clip-extent=false opacity value=0.11 ] dst-over aux=[ ref=y color-overlay value=black gaussian-blur std-dev-x=2 std-dev-y=2 abyss-policy=none clip-extent=false opacity value=1.1 ] "\
state->nr = gegl_node_new_child (gegl, "operation", "gegl:noise-reduction", "iterations", 4, NULL);
state->graphcapture = gegl_node_new_child (gegl, "operation", "gegl:gegl", "string", largepart, NULL);
state->bevelhigh = gegl_node_new_child (gegl, "operation", "gegl:bevel", "type", 1, "blendmode", 2, "radius", 8.0, "elevation", 44.0, "depth", 11, NULL);
state->bevellow = gegl_node_new_child (gegl, "operation", "gegl:bevel", "type", 1, "blendmode", 4, "radius", 8.0, "elevation", 44.0, "depth", 11, NULL);
state->bevellow2 = gegl_node_new_child (gegl, "operation", "gegl:bevel", "type", 1, "blendmode", 1, "radius", 8.0, "elevation", 44.0, "depth", 11, NULL);
state->cubism = gegl_node_new_child (gegl, "operation", "gegl:cubism", "tile-size", 2.0, NULL);
state->nopgm = gegl_node_new_child (gegl, "operation", "gegl:nop", NULL);
state->nop0 = gegl_node_new_child (gegl, "operation", "gegl:nop", NULL);
state->nopconform = gegl_node_new_child (gegl, "operation", "gegl:nop", NULL);
state->nopy = gegl_node_new_child (gegl, "operation", "gegl:nop", NULL);
state->gaussian1 = gegl_node_new_child (gegl, "operation", "gegl:gaussian-blur", "std-dev-x", 2.0, "std-dev-y", 2.0, "clip-extent", FALSE, "abyss-policy", 0, NULL);
state->gaussian2 = gegl_node_new_child (gegl, "operation", "gegl:gaussian-blur", "std-dev-x", 3.5, "std-dev-y", 3.5, "clip-extent", FALSE, "abyss-policy", 0, NULL);
state->gaussian3 = gegl_node_new_child (gegl, "operation", "gegl:gaussian-blur", "std-dev-x", 3.5, "std-dev-y", 3.5, "clip-extent", FALSE, "abyss-policy", 0, NULL);
state->grainmerge = gegl_node_new_child (gegl, "operation", "gimp:layer-mode", "layer-mode", 47, "composite-mode", 0, "blend-space", 2, "opacity", 0.45, NULL);
state->behind = gegl_node_new_child (gegl, "operation", "gimp:layer-mode", "layer-mode", 29, "composite-mode", 0, "opacity", 0.78, NULL);
state->median = gegl_node_new_child (gegl, "operation", "gegl:median-blur", "radius", 2, "alpha-percentile", 70.0, "abyss-policy", 0, NULL);
state->normal = gegl_node_new_child (gegl, "operation", "gegl:over", NULL);
state->makewhite = gegl_node_new_child (gegl, "operation", "gegl:color-overlay", "value", white, NULL);
state->coloroverlay1 = gegl_node_new_child (gegl, "operation", "gegl:color-overlay", "value", secondcolor, NULL);
state->coloroverlay2 = gegl_node_new_child (gegl, "operation", "gegl:color-overlay", "value", thirdcolor, NULL);
state->glass = gegl_node_new_child (gegl, "operation", "lb:glassovertext", "azimuth", 94.0, "hyperopacity", 0.3, "elevation", 45.0, NULL);
state->alienmap = gegl_node_new_child (gegl, "operation", "gegl:alien-map", "cpn-1-frequency", 3.6, "cpn-2-frequency", 2.9, "cpn-3-frequency", 7.5, NULL);
/*meta redirect property to new child orders go here
gegl_operation_meta_redirect (operation, "propertyname", state->newchildname, "originalpropertyname"); */
gegl_operation_meta_redirect (operation, "cpn_1_frequency", state->alienmap, "cpn_1_frequency"); gegl_operation_meta_redirect (operation, "cpn_2_frequency", state->alienmap, "cpn_2_frequency"); gegl_operation_meta_redirect (operation, "cpn_3_frequency", state->alienmap, "cpn_3_frequency"); gegl_operation_meta_redirect (operation, "azimuth", state->glass, "azimuth"); gegl_operation_meta_redirect (operation, "seed", state->cubism, "seed"); gegl_operation_meta_redirect (operation, "tile-size", state->cubism, "tile-size"); gegl_operation_meta_redirect (operation, "elevation", state->bevelhigh, "elevation"); gegl_operation_meta_redirect (operation, "elevation", state->bevellow, "elevation"); gegl_operation_meta_redirect (operation, "elevation", state->bevellow2, "elevation"); gegl_operation_meta_redirect (operation, "base-blur", state->gaussian1, "std-dev-x"); gegl_operation_meta_redirect (operation, "base-blur", state->gaussian1, "std-dev-y"); gegl_operation_meta_redirect (operation, "grow", state->median, "alpha-percentile"); gegl_operation_meta_redirect (operation, "bg_opacity", state->behind, "opacity"); }
static void update_graph (GeglOperation *operation) { GeglProperties *o = GEGL_PROPERTIES (operation); State *state = o->user_data; if (!state) return; GeglNode *bevel = state->bevellow2;
switch (o->puffblend) { case GEGL_BEVEL_HIGHPUFF: bevel = state->bevelhigh; break; case GEGL_BEVEL_LOWPUFF: bevel = state->bevellow; break; case GEGL_BEVEL_LOWPUFF2: bevel = state->bevellow2; break; default: bevel = state->bevellow2;
gegl_node_link_many (state->input, state->gaussian1, state->nop0, state->makewhite, state->cubism, state->median, state->nopconform, state->gaussian2, state->coloroverlay1, bevel, state->graphcapture, state->nopgm, state->grainmerge, state->nr, state->normal, state->behind, state->output, NULL);
gegl_node_link_many (state->nopgm, state->alienmap, NULL); gegl_node_connect (state->grainmerge, "aux", state->alienmap, "output");
gegl_node_link_many (state->nop0, state->glass, NULL); gegl_node_connect (state->normal, "aux", state->glass, "output"); gegl_node_connect (state->behind, "aux", state->gaussian3, "output"); gegl_node_link_many (state->nopconform, state->coloroverlay2, state->gaussian3, NULL); }
static void gegl_op_class_init (GeglOpClass *klass) { GeglOperationClass *operation_class; GeglOperationMetaClass *operation_meta_class = GEGL_OPERATION_META_CLASS (klass); operation_class = GEGL_OPERATION_CLASS (klass);
operation_class->attach = attach; operation_meta_class->update = update_graph;
gegl_operation_class_set_keys (operation_class, "name", "lb:bubble", "title", _("Bubble Text"), "reference-hash", "bubblebuddyheydontigetasayinthis", "description", _("Make text that looks like soapy bubbles"), /*<Image>/Colors <Image>/Filters are top level menus in GIMP*/ "gimp:menu-path", "<Image>/Filters/Text Styling", "gimp:menu-label", _("Bubble text..."), NULL); }
#endif
and /* This file is an image processing operation for GEGL * * GEGL is free software; you can redistribute it and/or * modify it under the terms of the GNU Lesser General Public * License as published by the Free Software Foundation; either * version 3 of the License, or (at your option) any later version. * * GEGL is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU * Lesser General Public License for more details. * * You should have received a copy of the GNU Lesser General Public * License along with GEGL; if not, see <https://www.gnu.org/licenses/>. * * Credit to Øyvind Kolås (pippin) for major GEGL contributions * Glass over Text 2023 Beaver */
/*GEGL Glass Over Text was once just a stand alone plugin, but now it is also part of GEGL Effects. The stand alone version still exist and does more then the GEGL Effects implementation of it. */
/* GEGL Graph Below */
/* color-overlay value=#ffffff gaussian-blur std-dev-x=1 std-dev-y=1 emboss azimuth=44 depth=29 id=1 gimp:layer-mode layer-mode=erase composite-mode=auto aux=[ ref=1 dst-over aux=[ color value=#000000 ] crop color-to-alpha opacity-threshold=0.14 color-overlay value=#000000 ] ] color-overlay value=#ffffff gaussian-blur std-dev-x=0 std-dev-y=0 */
/*GEGL Graph here. NOTE FOR DEVS replacing"gimp:layer-mode layer-mode=erase with gegl:xor does not work proper. I tried and you can try it too and watch it fail. GEGL blend modes are not as good as Gimp blend modes */
/*This is the enum list of glass text's blend mode switcher.*/ enum_start (gegl_blend_mode_type_glasstext) enum_value (GEGL_BLEND_MODE_TYPE_GLASSOVER, "Replace", N_("Replace")) enum_value (GEGL_BLEND_MODE_TYPE_GRAINMERGEGLASS, "GrainMerge", N_("GrainMerge")) enum_value (GEGL_BLEND_MODE_TYPE_LINEARLIGHTGLASS, "LinearLight", N_("LinearLight")) enum_value (GEGL_BLEND_MODE_TYPE_SUBTRACTGLASS, "Subtract", N_("Subtract")) enum_value (GEGL_BLEND_MODE_TYPE_OVERLAYGLASS, "Overlay", N_("Overlay")) enum_value (GEGL_BLEND_MODE_TYPE_NORMALGLASS, "Normal", N_("Normal")) enum_end (geglblendmodetypeglasstext)
property_enum (glassover, _("Blend Mode of Glass on Text"), geglblendmodetypeglasstext, gegl_blend_mode_type_glasstext, GEGL_BLEND_MODE_TYPE_GLASSOVER) ui_meta ("role", "output-extent")
property_boolean (enableglasstext, _("Enable Glass on Text for GEGL Effects"), TRUE) description (_("This option is only for GEGL Effects")) ui_meta ("role", "output-extent") /* ui_meta ("role", "output-extent") hides this from showing up in the GUI */
#define TUTORIALGLASSTEXT \ " id=1 gimp:layer-mode layer-mode=erase composite-mode=auto aux=[ ref=1 dst-over aux=[ color value=#000000 ] color-to-alpha opacity-threshold=0.14 color-overlay value=#000000 ] ] "\
property_double (azimuth, _("Azimuth"), 30.0) description (_("Light angle (degrees)")) value_range (0, 360) ui_meta ("unit", "degree") ui_meta ("direction", "ccw") ui_steps (0.5, 0.50)
property_int (depth, _("Depth"), 20.0) description (_("Filter width")) value_range (10, 100)
property_double (elevation, _("Elevation"), 45.0) description (_("Elevation angle (degrees)")) value_range (40, 46) ui_meta ("unit", "degree") ui_steps (0.1, 0.50)
property_double (std_dev, _("Retract Shine"), 3.0) description (_("Add a Gaussian Blur")) value_range (1, 3) ui_range (1, 3) ui_gamma (3.0) ui_meta ("unit", "pixel-distance") ui_steps (0.1, 0.50)
property_double (blur, _("Blur Shine"), 0.5) description (_("Add a Gaussian Blur")) value_range (0.5, 1) ui_range (0.5, 1) ui_gamma (3.0) ui_steps (0.1, 0.50) ui_meta ("unit", "pixel-distance")
property_color (color, _("Color"), "#ffffff") description (_("The color to paint over the input"))
property_double (hyperopacity, _("Hyper Opacity"), 1.0) description (_("Opacity Above 100 to make effect more noticable")) value_range (0.3, 1.5) ui_range (1.0, 1.5) ui_steps (0.1, 0.50)
#else
#define GEGL_OP_META #define GEGL_OP_NAME glassovertext #define GEGL_OP_C_SOURCE glassovertext.c
typedef struct { GeglNode *input; GeglNode *emboss; GeglNode *color; GeglNode *white; GeglNode *retract; GeglNode *gaussian; GeglNode *hyperopacity; GeglNode *string; GeglNode *normal; GeglNode *glassover; GeglNode *glassgrainmerge; GeglNode *glasslinearlight; GeglNode *glasssubtract; GeglNode *glassoverlay; GeglNode *output; }State;
GeglNode *blendglass = state->glassover; /* the default */ switch (o->glassover) { case GEGL_BLEND_MODE_TYPE_GLASSOVER: blendglass = state->glassover; break; case GEGL_BLEND_MODE_TYPE_GRAINMERGEGLASS: blendglass = state->glassgrainmerge; break; case GEGL_BLEND_MODE_TYPE_LINEARLIGHTGLASS: blendglass = state->glasslinearlight; break; case GEGL_BLEND_MODE_TYPE_SUBTRACTGLASS: blendglass = state->glasssubtract; break; case GEGL_BLEND_MODE_TYPE_OVERLAYGLASS: blendglass = state->glassoverlay; break; case GEGL_BLEND_MODE_TYPE_NORMALGLASS: blendglass = state->normal; break; default: blendglass = state->glassover;
} if (o->enableglasstext) { gegl_node_link_many (state->input, blendglass, state->output, NULL); gegl_node_link_many (state->input, state->white, state->retract, state->emboss, state->string, state->color, state->hyperopacity, state->gaussian, NULL); gegl_node_connect (blendglass, "aux", state->gaussian, "output"); } else gegl_node_link_many (state->input, state->output, NULL); }
static void attach (GeglOperation *operation) { GeglProperties *o = GEGL_PROPERTIES (operation); GeglNode *gegl = operation->node; GeglNode *input, *output, *emboss, *color, *glassover, *normal, *glassgrainmerge, *glasslinearlight, *glasssubtract, *glassoverlay, *white, *retract, *gaussian, *hyperopacity, *string; GeglColor *white_color = gegl_color_new ("rgb(1.1,1.1,1.1)");
input = gegl_node_get_input_proxy (gegl, "input"); output = gegl_node_get_output_proxy (gegl, "output");
normal = gegl_node_new_child (gegl, "operation", "gimp:layer-mode", "layer-mode", 28, NULL);
emboss = gegl_node_new_child (gegl, "operation", "gegl:emboss", NULL);
string = gegl_node_new_child (gegl, "operation", "gegl:gegl", "string", TUTORIALGLASSTEXT, NULL);
hyperopacity = gegl_node_new_child (gegl, "operation", "gegl:opacity", NULL);
retract = gegl_node_new_child (gegl, "operation", "gegl:gaussian-blur", "clip-extent", FALSE, "abyss-policy", 0, NULL);
gaussian = gegl_node_new_child (gegl, "operation", "gegl:gaussian-blur", "clip-extent", FALSE, "abyss-policy", 0, NULL);
color = gegl_node_new_child (gegl, "operation", "gegl:color-overlay", NULL);
white = gegl_node_new_child (gegl, "operation", "gegl:color-overlay", "value", white_color, NULL);
/* Glass Over Text blend modes for GEGL Effects */
glassover = gegl_node_new_child (gegl, "operation", "gegl:src-in", NULL);
glasslinearlight = gegl_node_new_child (gegl, "operation", "gimp:layer-mode", "layer-mode", 50, "composite-mode", 0, "blend-space", 3, NULL);
glassgrainmerge = gegl_node_new_child (gegl, "operation", "gimp:layer-mode", "layer-mode", 47, "composite-mode", 0, "blend-space", 3, NULL);
glasssubtract = gegl_node_new_child (gegl, "operation", "gimp:layer-mode", "layer-mode", 34, "composite-mode", 0, NULL);
glassoverlay = gegl_node_new_child (gegl, "operation", "gimp:layer-mode", "layer-mode", 23, "composite-mode", 0, NULL);
gegl_operation_meta_redirect (operation, "std_dev", retract, "std-dev-x"); gegl_operation_meta_redirect (operation, "std_dev", retract, "std-dev-y"); gegl_operation_meta_redirect (operation, "blur", gaussian, "std-dev-x"); gegl_operation_meta_redirect (operation, "blur", gaussian, "std-dev-y"); gegl_operation_meta_redirect (operation, "azimuth", emboss, "azimuth"); gegl_operation_meta_redirect (operation, "elevation", emboss, "elevation"); gegl_operation_meta_redirect (operation, "depth", emboss, "depth"); gegl_operation_meta_redirect (operation, "color", color, "value"); gegl_operation_meta_redirect (operation, "hyperopacity", hyperopacity, "value");
/* now save references to the gegl nodes so we can use them * later, when update_graph() is called */ State *state = g_malloc0 (sizeof (State)); state->input = input; state->white = white; state->retract = retract; state->emboss = emboss; state->string = string; state->normal = normal; state->color = color; state->hyperopacity = hyperopacity; state->gaussian = gaussian; state->glassover = glassover; state->glassgrainmerge = glassgrainmerge; state->glasslinearlight = glasslinearlight; state->glasssubtract = glasssubtract; state->glassoverlay = glassoverlay; state->output = output;
o->user_data = state;
gegl_operation_class_set_keys (operation_class, "name", "lb:glassovertext", "title", _("Glass Over Text"), "reference-hash", "stglass238a5125700fc254001b2ac", "description", _("Glass Over Text Effect - Filter expects user to place effect on layer above or use the normal blend mode. It may even be a good idea to experiment with other blend modes."), "gimp:menu-path", "<Image>/Filters/Text Styling", "gimp:menu-label", _("Glass over text (to blend)..."), NULL); }
#endif
