It is currently Mon Nov 16, 2026 6:31 pm
 Post subject: Seeking Update on Old Plugin
PostPosted: Thu Apr 02, 2026 2:05 am  (#1)
I hope I'm in the right place and asking (at least mostly) the right question. If not, please let me know.
I am currently on a MacBook Pro, running OS26.0.1, and with GIMP 3.0.6 installed. Years ago, Ofnuts created a python plugin to perform a specific task on images that I utilize in my machine knitting. The last time we worked together was 2016, and until I was forced into a new computer (and updated version of GIMP) in December, all was well. Now it no longer works.
If Ofnuts sees this and is willing, I would love to see if an updated version is possible.
Or, if not, perhaps someone else in this community would be willing to give it a try.
I am more grateful than you can know for the power that GIMP, and 'my special plugin', have given me in my creative process.
 Post subject: Re: Seeking Update on Old Plugin
PostPosted: Thu Apr 02, 2026 3:51 am  (#2)
You are more likely to find Ofnuts here https://www.gimp-forum.net/
You know if you still have the old plugin for Gimp-2.10 you can just install Gimp-2.10 alongside of Gimp-3 versions. Hence being able to use it again. :) :bigthup
If you are looking for his plugins you will find most of them here.
https://sourceforge.net/projects/gimp-p ... s/scripts/
And here.
https://sourceforge.net/projects/gimp-t ... s/scripts/
PostPosted: Thu Apr 02, 2026 5:50 am  (#3)
Can you help me to find where I can download Gimp-2.10?
PostPosted: Thu Apr 02, 2026 7:59 am  (#4)
Very possibly going to depend on your MacOS version but someone had some luck here
https://www.gimp-forum.net/Thread-Gimp- ... 4#pid46454
A list of dmg here: https://download.gimp.org/gimp/v2.10/osx/
PostPosted: Thu Apr 02, 2026 12:41 pm  (#5)
Thank you.
PostPosted: Thu Apr 02, 2026 2:00 pm  (#6)
It all worked! The plugin was still available and loaded with the older version that I was able to download.
Thank you, thank you, thank you!!!!!
PostPosted: Thu Apr 02, 2026 9:20 pm  (#7)
Happy to help. :) :bigthup
@ Rich.
Thanks for the download links. :hi5
