It is currently Mon Aug 10, 2026 10:37 am
 Post subject: Calling a system brush in a script (soap bubble) [SOLVED]
PostPosted: Thu Jul 21, 2011 8:48 pm  (#1)
This is for gimp 2.6.11.
This is a request for Gimp v 2.6.11. The soap bubble script calls for the Circle Fuzzy (07) brush but it tries to get it from the userfiles brushes. Although it works fine copied into the userfiles, I would like for it to get the one that's already in the brush files that come with gimp.
My 2 attempts at changing it didn't work. I expect there's a way to call a system brush.
(gimp-context-set-foreground '(0 0 0))
(gimp-brushes-set-brush "Circle Fuzzy (07)")
(gimp-selection-load chan1)
(set! space(car (gimp-brushes-get-spacing))) ;in order to preserve previous brush spacing
(gimp-brush-set-spacing "Circle Fuzzy (07)" 0)
(gimp-edit-stroke rim2)
(gimp-brush-set-spacing "Circle Fuzzy (07)" space) ;reload original spacing
(gimp-selection-invert img)
(gimp-edit-clear rim2)
What I changed it to. I also tried it without .vbr in the name.
(gimp-brushes-set-brush "Circle-Fuzzy-7.vbr")
(gimp-brush-set-spacing "Circle-Fuzzy-7.vbr" 0)
(gimp-brush-set-spacing "Circle-Fuzzy-7.vbr" space) ;reload original spacing
O note: I have removed the attached SoapBubble2.4.scm because GnuTux has updated the script to SoapBubble2.6.scm below.
 Post subject: Re: Calling a system brush in a script
PostPosted: Thu Jul 21, 2011 9:30 pm  (#2)
To select the brush, you can use..
(gimp-context-set-brush "Circle Fuzzy (07)")
PostPosted: Thu Jul 21, 2011 9:37 pm  (#3)
I don't understand where to put that in the script.
This is where it is in the original script.
PostPosted: Thu Jul 21, 2011 9:42 pm  (#4)
It would replace
..which has been depreciated.
Also, I removed the code which saves the brush spacing and replaced it with an overall context push & pop to the stack, so as to maintain your initial settings.
Here's the new black rim block...
;making the black rim
File comment: Soap Bubble (2.6)
SoapBubble2.6.scm [7.54 KiB]
Downloaded 253 times
PostPosted: Thu Jul 21, 2011 10:14 pm  (#5)
Thank you very much. That is much better. :teeth
 Post subject: Re: Calling a system brush in a script (soap bubble) [SOLVED]
PostPosted: Fri Jul 22, 2011 2:52 am  (#6)
Hey Tux is there as way to just call the current brush?
That might make for some cool looking designs in itself. :)
That way if i wanted i could use any same sized circular brush i have like a vector one.
PostPosted: Fri Jul 22, 2011 3:04 am  (#7)
Yes. Just comment out...
; (gimp-context-set-brush "Circle Fuzzy (07)")
.... to use the currently selected brush.
PostPosted: Fri Jul 22, 2011 3:21 am  (#8)
Thanks Tux! :bigthup
Here is one with the sparks brush. :)
PostPosted: Fri Jul 22, 2011 4:14 am  (#9)
Wouldn't it be safer for the script (and maybe more accurate) to create the brush from scratch (gimp-brush-new(), gimp-brush-set-{shape|radius|hardness|spacing|spikes|...})?
PostPosted: Fri Jul 22, 2011 6:09 am  (#10)
Many scripts do create a temporary brush.
It depends on the skill and experience of the script writer.
PostPosted: Fri Jul 22, 2011 11:31 am  (#11)
Feel free to hack away. It's not my script. :mrgreen:
PostPosted: Fri Jul 22, 2011 3:07 pm  (#12)
I only hack python, I have high standards :)
Now finding a way to escape the Wrath Of SaulGoode
PostPosted: Fri Jul 22, 2011 3:08 pm  (#13)
:teeth
PostPosted: Fri Jul 22, 2011 3:34 pm  (#14)
Yes, if one wants to use a hack language, Python is the first one that comes to my mind. :drum
Ever notice that the longest threads in the forum are the ones trying to deal with Python problems?
PostPosted: Fri Jul 22, 2011 8:49 pm  (#15)
ewwwwwwwwwwwwwwwwww :)
