It is currently Fri Nov 13, 2026 2:59 am
 Post subject: Custom Font Paragrapher for Gimp 2.10 update to v2.8b
PostPosted: Fri Aug 21, 2026 2:26 am  (#1)
This small update provides an option to address the appearance of very thin 'joined-up writing' custom fonts that using kerning paths.
Download, unzip and place it in your Gimp 2.10 user folder.
Custom_Font_Paragrapher_v2_8b_Tabbed.zip [22.48 KiB]
Downloaded 158 times
The new option shown below:
By thin custom fonts I mean those that have a stroke width (not a layer width) of 20 pixels or less.
Try using without the option. if the joining strokes look misaligned, hit the undo key and try again with the new option set to 'With scaling method'.
An example to illustrate the problem with joins circled and the improved display below.
Q: Why use very thin custom fonts?
A: Why not!
 Post subject: Re: Custom Font Paragrapher for Gimp 2.10 update to v2.8b
PostPosted: Fri Aug 21, 2026 12:12 pm  (#2)
And the hits keep coming!
This is great Skinnyhouse!
You're a Living Custom Fonts Ledged indeed!
:coolthup
PostPosted: Sat Aug 22, 2026 1:41 am  (#3)
Skinnyhouse, Thanks for your new plugin! You're always improving methods for creating better custom fonts. :clap
PostPosted: Sun Aug 23, 2026 6:52 am  (#4)
Thank you Skinnyhouse! Another great tool for the Custom Font toolbox. :)
