It is currently Fri Nov 13, 2026 1:29 am
 Post subject: Regular Shape Maker for Gimp 2.10
PostPosted: Sat Oct 03, 2026 1:29 pm  (#1)
Last time I tried to do this GimpChat went down so fingers crossed...
This plug-in is a compilation of a couple of filters that I often use for generating a background or textured image using randomly sized and/or rotated shapes. The results are usually tweaked or refined with other filters before being used – usually for custom font faces.
Since you can use the filter to generate a significant number of layers I often convert the layer names to custom font format so that I can apply custom font filters to many layers in one go. You can apply filters to each individual layer – if you wish.
A recently used background image as an example, that uses 27 shape layers and makes use of embossing, bump-mapping and drop shadow filters in Gimp.
The accompanying Resources Folder contains the Regular Shape plug-in and an updated Layer Utilities filter (version 1.37 Tabbed). You can download other Custom Font filters and guides by following the link to my signature on GimpChat.
ShapeMakerv02_Resources.zip [36.41 KiB]
Downloaded 58 times
A pdf of this help guide:
Regular-ShapeMaker_Help.pdf [1.7 MiB]
Downloaded 53 times
Getting Started
So (assuming that you have downloaded and unzipped the filters and placed them in your Gimp 2.10 user plug-ins folder) open Gimp 2.10 and add a new image, with a transparent background.
Call up the filter dialog:
Filters>>Regular Shape Maker Tabbed v0.2 Tabbed…
Use the Gradient option to select a gradient: Regular Shape Maker will randomly choose a colour from the current gradient. If you want to use colours from the custom BG-FG gradient do this before calling up the filter.
Select the shape and number of shapes to add to the image and hit ‘OK’.
I used a Red-Blue custom gradient with pentagons and generated 8 shapes.
The default options randomly set the size and position of each shape and crops each layer to fit each shape.
The default cropping option allows you to drag the shapes around and re-position them if you are not satisfied with the initial outcome.
If any shapes are completely hidden, you can always re-order the hidden layer in the layers dock tool pane, moving it nearer the top of the layer tree.
By default, the shapes are placed with a rotation of zero degrees. You can set your own angle of rotation or use random rotation for each shape.
The following example uses a mix of 10 shapes, sizes and rotations with a coloured gradient.
My dialog options:
The initial outcome:
Two of the smaller shapes were hidden, so a little re-ordering was required.
I could have run the filter again to generate more layers.
There is an option to focus the generated size of shapes to larger or smaller sizes…
Adding Effects
Before adding effects to the plain shape layers use the Custom Font Layer Utilities plug-in.
Filters>>Custom Fonts>>Utility Tools>>Custom Font Layer Utils v1.37 Tabbed
Use the ‘Force custom font names’ option Tab 3 of the dialog...
Then call the filter again. Set the same option to ‘No’ and then use the last option on Tab 2 to resize all layers to the image size. Some effects do not work very well without having transparent pixels around the layer content.
Many of the Custom Font Decorative Tools such as Effects Only, Artistic Pack, Noise Packs, Distortion Packs and Metallic Effects will now work with the layers in the image.
Refer to the help guides for each filter.
Apply a canvas texture option from the Artistic Pack to add a little interest to the layers.
Filters>>Custom Fonts>>Decorating Tools>>Custom Font Artistic Pack
The outcome:
Apply an emboss effect with the Effects Only plug-in.
Filters>>Custom Fonts>>Decorating Tools>>Custom Font Effects Only
The outcome…
Apply 3d with the Faux3D plug-in…
Filters>>Custom Fonts>>3D Tools>>Custom Font Faux 3D Tabbed...
[NB Effect applied to a different image - I lost the original.]
The outcome…
To be continued in part 2...
 Post subject: Re: Regular Shape Maker for Gimp 2.10
PostPosted: Sat Oct 03, 2026 1:39 pm  (#2)
And as a final effect, add a drop shadow using Tab 4 of the Layer Utilities dialog.
The outcome...
There is also an option to add drop shadows to existing shape layers on the second tab of the Regular Shapes dialog.
And of course a background layer completes the experience...
Have fun...
PostPosted: Sat Oct 03, 2026 8:36 pm  (#3)
Nice work, Skinnyhouse!
:jumpclap :clap :jumpclap
This looks like it could be really useful.
I can see all kinds of possibilities for it,
especially for creating backgrounds,
textures, patterns,
or just getting some interesting shapes onto the canvas.
I also like that you can have the shapes on separate layers and control their size,
rotation, and placement.
That gives you a lot to play with.
Very nice job,
and thanks for sharing it with us!
PostPosted: Sun Oct 04, 2026 12:15 am  (#4)
Very awesome addition to the CF toolbox Skinnyhouse! Thank you very much. :)
PostPosted: Sun Oct 04, 2026 2:57 am  (#5)
Thanks guys...
As I said - I have been using versions of this for quite a while to do all of those things that Wallace said.
Custom Font BRL also can be used as a decorative effect...
PostPosted: Sun Oct 04, 2026 9:01 am  (#6)
Thanks a lot for another wonderful decorative effect to create backgrounds.
:tyspin :paint :bigthup :clap
PostPosted: Wed Oct 07, 2026 7:44 am  (#7)
Thanks Issa :bigthup
A version that adds stars (5 points) to the shapes option...
Regular Shape Maker V0_3 Tabbed.zip [13.91 KiB]
Downloaded 37 times
PostPosted: Thu Oct 08, 2026 2:42 am  (#8)
Even better, Thanks Skinnyhouse. :coolthup
PostPosted: Thu Oct 08, 2026 3:45 am  (#9)
6 pointed stars done...
Regular Shape Maker V0_4 Tabbed.7z [12.86 KiB]
Downloaded 38 times
