It is currently Mon Aug 10, 2026 1:47 am
 Post subject: Check gimp version
PostPosted: Wed Jul 27, 2011 9:56 am  (#1)
I know there are changes coming up to the gimp API which may break scripts in 2.7+
I'm hoping to modify my 2.6 scripts to work with 2.8, and to help I created a little helper function to check the gimp version so I can then have the code make the appropriate call.
(define (gimp-version-meets? check)
  (let ((c (map string->number (strbreakup check ".")))
        (v (map string->number (strbreakup (car (gimp-version)) "."))))
  (if (> (car v) (car c)) #t (if (< (car v) (car c)) #f (if (> (cadr v) (cadr c)) #t (if (> (cadr v) (cadr c)) #f (if (>= (caddr v) (caddr c)) #t #f)))))))
There might be more elegant solutions then these nested if statements (Saulgoode?) but this seems to work fine.
So in a script you can use (gimp-version-meets? "2.7.1") and it will return #t if your running version of gimp is version 2.7.1 or later, and then have the appropriate calls made.
-Rob A>
 Post subject: Re: Check gimp version
PostPosted: Wed Jul 27, 2011 10:08 am  (#2)
Thanks Rob! :)
PostPosted: Wed Jul 27, 2011 10:21 am  (#3)
Well, to just find out if the version is at least 2.8 (or 2.7+), one could test for:
    (defined? 'gimp-image-get-items)
because that function doesn't exist in current versions ("items" are either drawables or groups of drawables, and there are no groups of drawables in GIMP <= 2.6).
PostPosted: Wed Jul 27, 2011 11:27 am  (#4)
I think you have a mistake: the second test of the cadr terms should be a less-than rather than a greater than.
Checking 2.7.1 against a gimp-version of 2.6.7 returns #t
edit:
Oops, you're testing (car v) is less than itself
PostPosted: Wed Jul 27, 2011 1:12 pm  (#5)
(deleted)
PostPosted: Wed Jul 27, 2011 3:46 pm  (#6)
I don't know if it's any more elegant, but here is an alternate solution:
  (let loop ((diffs (map - (map string->number (strbreakup check "."))
                           (map string->number (strbreakup (car (gimp-version)) ".")) ))
             (ok? #t) )
    (if (null? diffs)
      ok?
      (cond
        ((> (car diffs) 0)
          (loop '() #t) )
        ((zero? (car diffs))
          (loop (cdr diffs) ok?) )
        (else
          (loop (cdr diffs) #f) )))))
A shorter version (though not quite so obvious what is happening):
                           (map string->number (strbreakup (car (gimp-version)) ".")) )))
    (if (null? (cdr diffs))
      (>= (car diffs) 0)
      (if (zero? (car diffs))
        (loop (cdr diffs))
        (> (car diffs) 0) ))))
PostPosted: Wed Jul 27, 2011 7:37 pm  (#7)
edit:
oops. thanks, fixed.
-Rob A>
PostPosted: Sat Jul 30, 2011 2:21 pm  (#8)
I don't get it
PostPosted: Sat Jul 30, 2011 2:27 pm  (#9)
The script writers are re-writing their scripts so they will not be deprecated in Gimp-2.8 Alonte. :)
