It is currently Mon Aug 10, 2026 1:46 am
 Post subject: Gino-D updated his scripts
PostPosted: Sun Aug 28, 2011 11:52 pm  (#1)
Crossword grid is his latest new script.
Options are:
Number of columns / Number of rows
Specify the size of the crossword grid.
Cell width / Cell height
Determine the dimensions (in pixels) of every cell.
Color of lights
Sets the background color of the cells into which the letters shall be written.
Color of blocks
Sets the color of the shaded cells which separate the answers.
Cell border thickness / Cell border color
Define the width (in pixels) and the color of the inner border of the cell.
Block margins
Controls the distance (in pixels) between the cell borders and the edges of the block.
Maximum answer length
Specifies the maximum allowed length for the answers.
Ensure 180-degree rotational symmetry
Checking this box will cause the crossword grid to appear the same if turned upside down.
Insert clue numbers
When enabled, this option produces the numbering of the cells in which the answers begin.
Size of digit
As for the clue numbers, here you can specify the size of a single digit as a percentage with respect to the cell width.
Text color
Sets the color of the clue numbers.
Font
Lets you select the font for the clue numbers.
Keep layers separate
By checking this box, you will obtain a multi-layer image, where each layer depicts a different element of the crossword grid (background area; blocks; cell borders; clue numbers).
http://registry.gimp.org/node/25531
 Post subject: Re: Gino-D updated his scripts
PostPosted: Mon Aug 29, 2011 1:01 am  (#2)
Saw this at the registry earlier. Was trying to figure out some clever way to use it, but my brain's just inspired at the moment, but thanks for posting it here too Rod. Might download and play with it later. :)
PostPosted: Mon Aug 29, 2011 1:26 am  (#3)
Might make a nice addition to a website or web-magazine game area. :)
Hot Potato software used to make a puzzle creator like this that would add the clues.
Now that would be a nice addition to the script!
PostPosted: Mon Aug 29, 2011 4:59 am  (#4)
I downloaded that one yesterday but I have been adding the numbers myself. I see the one above already has the numbers. Am I missing something on the setup?
PostPosted: Mon Aug 29, 2011 7:24 am  (#5)
Nope just add "insert clue numbers" (tick the option), when you run the filter.
Select a font type, and color. :)
PostPosted: Mon Aug 29, 2011 7:48 am  (#6)
Thanks
