It is currently Sun Aug 16, 2026 3:41 am
 Post subject: GMIC new filter :"Symmetries Master"
PostPosted: Sat Nov 12, 2011 10:52 pm  (#1)
A new render pattern filter for gmic somehow similar to "Symmetric Deco" yet very different
GMIC Symmetry Master by PhotoComix_Mandala, on Flickr
A random examples
GMIC "Symmetry Master" output by PhotoComix_Mandala, on Flickr
The filter is ready but upload this time is a bit complex, i must take care to upload a lot of other new filters
(new layer mode and the new version of Graphic Novel ) because are required as dependencies
But for tomorrow should be in my source
 Post subject: Re: GMIC new filter :"Symmetries Master"
PostPosted: Sat Nov 12, 2011 11:26 pm  (#2)
cool and neato!
PostPosted: Sun Nov 13, 2011 12:11 am  (#3)
DONE now you may just refresh
you will find the filter in Patterns not under PhotoComix
PS i love the new child i can't stop playing with
PS
in Artistic you will found also the new versions of Graphic Novel and Graphic Boost...new version has the name enclosed by **...so **Graphic Novel ** is the last version that without ** the older
PostPosted: Sun Nov 13, 2011 12:24 am  (#4)
It's not there. Now my G'MIC Faves are totally messed up.
PostPosted: Sun Nov 13, 2011 12:33 am  (#5)
messed up by my upload ?
PostPosted: Sun Nov 13, 2011 12:36 am  (#6)
It was fine before you uploaded. Is there a limit to how many filters you can add to the .gmic file?
PostPosted: Sun Nov 13, 2011 12:52 am  (#7)
that is a question for David
I believe there is a limit for preset, for faves (i had more then 100 and weird things start to happen to the menu) but not sure for the filters.
As now you should see a lot of new filters under Photocomix filters but that are new combinations of layer mode,
that i need as dependency ...
Then the 2 new filters are in PATTERNS close to the bottom, and in Artistic you should see the new **Graphic Novel **and **Graphic Boost**, Phoenix Steam-pen , Mescalito Colors,Psychedelic Glasswork tiler,...
and in "Black & white" Steampunk pencil
PostPosted: Sun Nov 13, 2011 1:10 am  (#8)
OK, those filters are in the locations you mentioned, but this fave list weirdness has me baffled. I hope David can help clear it up.
PostPosted: Sun Nov 13, 2011 1:27 am  (#9)
me too, no problem with the faves the problem is above the fav , where should be nothing , there i see very weird things happening
PostPosted: Sun Nov 13, 2011 1:33 am  (#10)
The new Graphic Boost = no preview:
PostPosted: Sun Nov 13, 2011 2:13 am  (#11)
I have the preview .
please check if is a particular option that cause the problem, i can't replicate
But you already had a similar problem with the preview with the older version ..right ?
humm ...if you click OK works ?
another thing, set the output to new layer , run it and look the layer name ...after[gmic] and some ;; did you see "-gimp_graphic_novelfxl " or something else ?
Maybe gmic doesn't like the "**" in the name? but why for me works i moved away all local files to check, i just have the file from the server, from last refresh
PostPosted: Sun Nov 13, 2011 2:23 am  (#12)
It threw this error when running it:
*** Error in ./gimp_graphic_boost4/*repeat/*local/*local/ *** Command 'endif' : Not associated to a 'if' command within the same scope.
PostPosted: Sun Nov 13, 2011 2:42 am  (#13)
Aaahh... Graphic Boost not graphic Novel!
now fixed thank a lot for reporting
BTW what is new in GB as in GN are a much more options for merging, i created 9 variation of layer mode for
a similar use ,mainly to merge color images with BW derivate...
cron
