It is currently Mon Aug 17, 2026 12:13 am
 Post subject: (New version ) Graphic Novel 2
PostPosted: Wed Nov 16, 2011 5:32 pm  (#1)
A new version of Graphic Novel is out, you will see the difference from the name Graphic Novel 2
I added more option for recover colors from the original, for the merging:
i know were already many but the new one offers some interesting effects not available before
here some result of the new options to make a easier confront i only changed merging mode without modify other settings
ORIGINAL
Northeast Classic Racing @Broome Tioga Sports Center by jdanvers, on Flickr
Lightness mode
GRaphic Nove l2 test by PhotoComix_Mandala, on Flickr
"Colors Doping" mode...
"Dark Screen" but i suppose i should rename in something as "white flash"
i believe this was Vivid Edges
and this is Dark Edges ,(this type of effect is more clear when smoothing is lowered or skipped )
about OLD presets
it is very easy adapt old presets to this new version if you need to update some just post here so i may also use as example for how to do.
 Post subject: Re: (New version ) Graphic Novel 2
PostPosted: Wed Nov 16, 2011 6:19 pm  (#2)
what's graphic novel? i've never used it before
PostPosted: Wed Nov 16, 2011 8:26 pm  (#3)
GMIC ( Artistic menu ) my filter source should be enabled for the filter to show up
