It is currently Tue Aug 18, 2026 12:11 am
 Post subject: ColorBlur 3.0
PostPosted: Sun Nov 27, 2011 4:13 am  (#1)
I compiled the Colorblur-0.3.0 plugin for Gimp-2.7.4 Windows 32 bit.This is an update from version 2.
Should work in Gimp-2.6.11 also let me know. :)
Tested well in Gimp-2.6.11 also.
Installing-
Place the exe file in the plugins folder.
Explanation of what plugin does -
Selective Color Blurring
View
Revisions
November 9, 2011 - 05:21 — Tibor95
The plugin selectively blurs the color information (both hue and saturation) in image. There are two basic scenarios / reasons to use this: When saturating poorly saturated images and denoising noisy images. The plugin blurs selectively, and can even "sharpen" transitions between two colors.
The plugin have thee basic outputs - blur color on image, creating mask with fixed brightness (use hue mode for the layer afterwards) and Subordinate brightness blurring (see wiki link for explanation).
http://code.google.com/p/selective-colo ... troduction
Location in gimp: FILTERS -> BLUR -> COLOR SELECTIVE BLUR
Zip attached
colorblur-0.3.0.zip [46.63 KiB]
Downloaded 482 times
I didn't see anywhere in the registry where this was updated (the compile).Forgive me if it has already been compiled and i missed it somewhere's. :)
Enjoy!
 Post subject: Re: ColorBlur 3.0
PostPosted: Sun Nov 27, 2011 4:20 am  (#2)
Works with GIMP 2.6.11 32-bit in Win7 64-bit Rod. Thanks for the update. :)
PostPosted: Sun Nov 27, 2011 6:14 am  (#3)
No problem.
You beat me to the punch on testing it in 2.6.11 ... :lol :bigthup
PostPosted: Sun Nov 27, 2011 6:59 am  (#4)
thank Rod !
PostPosted: Sun Nov 27, 2011 8:50 am  (#5)
Will this work on a mac? And if so, where do the rest of the files go?
PostPosted: Fri Jan 04, 2013 6:24 pm  (#6)
New version and binaries : colorblur-0.3.7
(binaries & sources at the end of the page)
PostPosted: Fri Jan 04, 2013 7:13 pm  (#7)
Thanks for the update samj; cool to have this one for 64-bit and it's also 14K smaller then the original (not that that really matters, but I do like efficiency). :)
