It is currently Tue Aug 11, 2026 4:19 am
 Post subject: Is there a way to have Multi-line text in script-fu
PostPosted: Wed Nov 30, 2011 11:35 pm  (#1)
Is there a way to have Multi-line text in a script-fu
 Post subject: Re: Is there a way to have Multi-line text in script-fu
PostPosted: Thu Dec 01, 2011 12:02 am  (#2)
you could use SF-TEXT
Sorry for my poor English, I use Google Translate.
There may be something wrong, Please understand.
GIMP 2.10.38 rev1 portable+GAP+G'MIC+nufraw+Beautify+MathMap+...
PostPosted: Thu Dec 01, 2011 12:18 am  (#3)
Thanks James I new I had seen something about it some where but was not sure now I will search
PostPosted: Thu Dec 01, 2011 1:20 am  (#4)
Found it
PostPosted: Thu Dec 01, 2011 1:29 am  (#5)
Unicode for a carriage return is U + 2029, I don't know what the equivalent ascii code is for that (Alt + Numpad).
You can test this out if you have a script that requires text entries. Unicode only works in Linux, though.
I tested it out in the Shrek Text script.
PostPosted: Thu Dec 01, 2011 2:03 am  (#6)
'O' I found a good example of how to use in test sphere.scm and should work under any operating system.
instead of using
SF-STRING "Text" "Merry Xmas" to return Merry Xmas
use
SF-TEXT "Text" "Merry\nXmas" to return
Only change made everything else is the same
PostPosted: Thu Dec 01, 2011 2:15 am  (#7)
Way cool! :bigthup Works for me. The Unicode is faster though. Don't have to remember that string of text and I seriously doubt if I'll ever be writing any scripts.
PostPosted: Thu Dec 01, 2011 2:39 am  (#8)
Here is a 10 line test with nothing changed as before to check on bounding border and positioning.
PostPosted: Thu Dec 01, 2011 12:15 pm  (#9)
Offtopic :
? Where do you find what these SF- mean? I'm attempting to learn scripting and I've ran across SF-ADJUSTMENT now I see SF-TEXT. Is there a list of these some where??
I looked in http://www.gimp.org/docs/scheme ... -fu-gimp.html and found this:
(script-fu-register "script-fu-simple-drop-shadow"
                    _"<Image>/Script-Fu/Shadow/Drop-Shadow (simple)..."
                    "Add a simple drop-shadow of the alpha-channel"
                    "Simon Budig <[email protected]>"  ; author
                    "Simon Budig"                ; copyright holder
                    "2002/2/3"                   ; date
                    "RGBA GRAYA"                 ; image types
                    SF-IMAGE "Image" 0
                    SF-DRAWABLE "Drawable" 0
                    SF-ADJUSTMENT _"Offset X" '(8 -4096 4096 1 10 0 1)
                    SF-ADJUSTMENT _"Offset Y" '(8 -4096 4096 1 10 0 1)
                    SF-COLOR      _"Color" '(0 0 0)
                    SF-ADJUSTMENT _"Opacity" '(75 0 100 1 10 0 0))
Below it says:
You can specify SF-COLOR for colors, SF-TEXT for text and some other stuff.
Still can't find where all the SF-'s are! :(
Sorry this is off topic. :(
PostPosted: Thu Dec 01, 2011 2:32 pm  (#10)
http://www.ve3syb.ca/wiki/doku.php?id=s ... block-args
PostPosted: Thu Dec 01, 2011 7:47 pm  (#11)
Try reading these
<Menu>Filters/Script-Fu/Test/Sphere
Could not find specific info on SF-TEXT yet but if you read the Test sphere script it will give some info at the top. I'm still looking for better discription, Why it's been overlooked till now I don't know.
