It is currently Wed Aug 12, 2026 2:45 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
 Post subject: GMIC new filter " Black Crayon Graffiti"
PostPosted: Thu Dec 08, 2011 1:32 pm  (#1)
I just upload a new filter ,you should find in the Artistic submenu "Black Brayons Graffiti"
Emulate quite well a peculiar technique of graffiti ...well i already give details on the original technique and explained the manual steps here viewtopic.php?f=11&t=3238
Here the controls
GMIC- Black Crayon Graffiti by PhotoComiX, on Flickr
here a ...After/before
testing ducks by PhotoComiX, on Flickr
BEFORE
HFF my dearest ones like never before by zenera, on Flickr
about the mixing option Color Doping the default is a combination of Lightness and Grain Merge, Value is the same that in gimp . Lightness is similar to value but based on another mode to detect luminosity
 Post subject: Re: GMIC new filter " Black Crayon Graffiti"
PostPosted: Thu Dec 08, 2011 2:30 pm  (#2)
Nice PC! :)
Thanks.
PostPosted: Thu Dec 08, 2011 2:37 pm  (#3)
Original
Crayon
PostPosted: Thu Dec 08, 2011 2:50 pm  (#4)
Not showing up for me and I've refreshed G'MIC countless times.
PostPosted: Thu Dec 08, 2011 3:29 pm  (#5)
O maybe you should update gmic :
Not that the filter require a new version but the filter update doesn't work anymore for older version because a slightly change in the file name
If you don't want update now you may paste this in your .gmic or gmic file (newer version of Gmic require file without the dot )
#@gimp Black Crayon Graffiti : gimp_crayongraffiti2, gimp_crayongraffiti2_preview(0)
#@gimp : Amplitude = float(300,0,4000)
#@gimp : Density = float(50,0,100)
#@gimp : Smoothness = float(1,0,10)
#@gimp : Opacity = float(0.4,0,1)
#@gimp : Edge = float(12,0,50)
#@gimp : Fast approximation = bool(1)
#@gimp : Color Smoothness =float(2,1,30)
#@gimp : Mixer Style = choice(2,"Lightness","Value","Color Doping")
#@gimp : sep = separator(), Preview type = choice("Full","Forward horizontal","Forward vertical","Backward horizontal","Backward vertical")
#@gimp : sep = separator(), note = note("<small>Author : <i>PhotoComix-strictly derived from "Hard Sketch" from David Tschumperl&#233;</i>. Latest update : <i>2011/12/7</i>.</small>")
gimp_crayongraffiti2 :
--blur $3 -hardsketchbw[-1] $1,$2,$4,$5,$6 -to_rgb
-negative[-1] -blur_xy[-2] $7,$7 -reverse
-if {$8==0} -compose_lightness
-elif {$8==1} -compose_value
-elif {$8==2} -gimp_compose_colordoping 1,1 -endif
gimp_crayongraffiti2_preview :
-gimp_split_preview "-gimp_crayongraffiti2 ${1--2}",$-1
PostPosted: Thu Dec 08, 2011 6:10 pm  (#6)
I thought I would post these
Nice filter for that electrified look
PostPosted: Thu Dec 08, 2011 6:56 pm  (#7)
Where does it show up in GMI'C? I ahve refreshed, think it added it but can't find it or could my problem e the same as above?
PostPosted: Thu Dec 08, 2011 7:06 pm  (#8)
Artistic
if doesn't show up you should update gmic, something changed in the very last gmic version so filter update doesn't work anymore for old version (at least on windows)
May seems working but the right files are not read
PostPosted: Thu Dec 08, 2011 8:03 pm  (#9)
Ok seems I need to update, do you have a link for the latest version?
PostPosted: Thu Dec 08, 2011 9:59 pm  (#10)
PhotoComix wrote:
Artistic
Your version is 1.5.0.7 in your picture, my version is also 1.5.0.7 as evidenced by my picture. I was careful to have it show the version number in mine.
I was looking in Faves for it as that is what your image shows, PhotoComix. When I looked in Artistic, there it was.
PostPosted: Thu Dec 08, 2011 10:19 pm  (#11)
Love this effect...I am going to have to learn how to add .gmic filters so I can have this.
PostPosted: Thu Dec 08, 2011 10:57 pm  (#12)
You just need to update your G'MIC plug-in to G'MIC v1.5.0.7. Be sure you close and re-open GIMP, then open G'MIC and click the Refresh button. The Black Crayon Graffiti filter is in G'MIC > Artistic > Black Crayon Graffiti. It's a fun filter. :mrgreen:
PostPosted: Thu Dec 08, 2011 11:10 pm  (#13)
I have an older mac version of G'Mic and haven't upgraded to the new one that refreshes because I'm not sure it will work on a mac.
PostPosted: Fri Dec 09, 2011 6:06 am  (#14)
If you go to http://sourceforge.net/projects/gmic/ and select Browse All Files it shows 1.5.0.7 downloads suitable for different MAC systems.
PostPosted: Fri Dec 09, 2011 8:15 am  (#15)
Actually last is 1.5.0.8 beta i saw that is available for several mac flavors
knowing David the beta are pretty stable...i tell also because i am not sure from what version the filter update has stopped to work
(again it didn't really stopped to work but at least on win , the file to dl changed names,the difference is that there is no more a dot before the name)
0 the emu come out quite well...
PostPosted: Fri Dec 09, 2011 8:44 am  (#16)
I think mine (using windows) gave problems updating with 1.5.0.6 now OK with 1.5.0.7
PostPosted: Fri Dec 09, 2011 8:58 am  (#17)
Thanks graechan, for the link. I think 1507 is stable, yes? Anyone know for sure if 1508 will work for all the previous additions? And all I have to do is drag the exe file onto the gimp-gmic folder? yes Akky? I will check it out this afternoon when I get home. I am excited to be able to refresh for new filters!!!!
PostPosted: Fri Dec 09, 2011 9:03 am  (#18)
2-ton wrote:
Thanks graechan, for the link. I think 1507 is stable, yes? And all I have to do is drag the file onto the gimp-gmic folder? yes Akky?
Dunno about Macs, but gmic is in my /.gimp-2.6/plug-ins folder.
PostPosted: Fri Dec 09, 2011 9:08 am  (#19)
my current gmic_gimp folder is in my username/library/application support/gimp/_ plug-ins folder and works fine there.
PostPosted: Fri Dec 09, 2011 9:22 am  (#20)
Yes, it's in your plug-ins folder. The actual name of the plug-in is gmic_gimp. If you drag and drop it into your plug-ins folder, it should overwrite the one that is in there. It probably will ask you if you want to overwrite the file in there.
