It is currently Mon Aug 10, 2026 9:19 pm
 Post subject: New gallery for the plug-in effects in G'MIC
PostPosted: Wed Feb 15, 2012 11:15 pm  (#1)
Ronounours says:
http://www.flickr.com/groups/gmic/discuss/72157629332434231/
Hi there,
I've updated the web page: gmic.sourceforge.net/gimp.shtml
and added screenshots of most of the effects available in the G'MIC plug-in for GIMP. Now, users can have a nice overview of the plug-in possibilities, before installing it.
Hope it will attract more people to the plug-in (and hopefully the command line tool too !).
Let me know if you have further suggestions to improve this page.
Maybe also could use an alphabetical list
Alphabetical list of filters G'MIC (with location in the menu)
3d colored object -> Rendering
3D Conversion -> {Tom Keil's filters} -> Sterescopic 3D
3d conversion -> Rendering
3d elevation -> Rendering
3d elevation -> Sequences
3d extrusion -> Rendering
3d extrusion -> Sequences
3d image object -> Rendering
3d image object -> Sequences
3d lathing -> Rendering
3d random objects -> Rendering
3D Video Conwersion -> {Tom Keil's filters} -> Sterescopic 3D
60's Cinema -> {Gentlemanbeggar's filters}
60's Cinema -> Colors
A
A-color -> Colors -> Lab Curves
Abstract Flood -> {Naggobot's filters}
Abstraction -> Colors
Additive noise -> Degradations
Adjust orientation -> Various -> Experimental
Alpha blending -> Layers
Angular blur -> Degradations
Anisotropic smoothing (16bits) -> Various -> Experimental
Anti Alias -> {Garagecoder's tests}
Anisotropic smoothing -> Enhancement
Anisotropic smoothing -> Sequences
Automatic depth estimation -> {Tom Keil's filters} -> Sterescopic 3D
Average -> Layers
B
B-color -> Colors -> Lab Curves
B&W dithering -> Colors
B&W pencil -> Sequences
B&W recolorize -> Colors
B&W stencil -> Sequences
Banding denoise -> {Iain Fergusson's G'MIC Filters}
Bandpass filter -> Degradations
Bayer filter -> Degradations
Bayer reconnstruction -> Degradations
Beauty Retouch -> Presets / Testing
Bilateral filtering -> Enhancement
Black & White -> Colors
Black Crayon Grafifiti -> Artistic
Blue -> Colors -> RGB Curves
Blue chrominance -> Colors -> YCbCr Curves
Boost Screen -> {PhotoComix Filters}
Bost / Fade -> Colors
BW Steampunk-Pen -> Black & white
C
Canvas -> Patterns
Canvas texture -> Patterns
Cartesian transform -> Deformations
Cartoon -> Artistic
Cartoon -> Sequences
Channel processing -> Colors
Charcoal -> Black & white
Chessboard -> Patterns
CImg Skelton -> {KaRo's Test}
Circlism -> Artistic
CLmg nlmeans -> {KaRo's Test}
CMYK mixer -> Colors
CMYK tone -> {Iain Fergusson's G'MIC Filters}
Color balance -> Colors
Color burn -> Layers
Color Doping -> {PhotoComix Filters}
Color Sketch -> Artistic
Color Stamp -> Artistic
Color/Brightness decompose -> {Ronounours}
ColorAbstractionPaint -> Artistic
Colored Pencils -> Artistic
Colormap -> Colors
Comix Colors -> {PhotoComix Filters}
Compression Blur -> {Garagecoder's tests}
Contrast swiss mask -> Lights & Shadows
Corner gradient -> Colors
Cracks -> Patterns
Cube frame -> Arrays & frames
Cubism -> Artistic
Curvature -> Contours
Curves -> Colors
Custom code (global) -> Various
Custom code (local) -> Various
D
Dark Edges -> {PhotoComix Filters}
Dark Screen -> {PhotoComix Filters}
Darken -> Layers
Decompose channels -> Colors
Deconvolution -> Enhancement
Deinterlace -> Enhancement
Depth map construction -> {Tom Keil's filters} -> Sterescopic 3D
Dices -> Patterns
Difference -> Layers
Difference of gaussians -> Contours
Discrrete color square -> Presets / Testing
Distance transform -> Contours
Divide -> Layers
Do nothing -> Various
Dodge -> Layers
Dodge sketch -> {Naggobot's filters}
DOF manipulation -> {Tom Keil's filters}
Doge and Burn -> Lights & Shadows
Dots -> Patterns
DR Adjust -> {Iain Fergusson's G'MIC Filters}
Drop shadow -> Lights & Shadows
Dynamic Range Increase -> {Tom Keil's filters}
Dynamic Range Increase -> Enhancement
E
Edge-preserving flow -> Enhancement
Edges -> Contours
Edges -> Layers
Edges -> Sequences
Edges offsets -> Contours
Edges on fire -> Sequences
Elipsionism -> Artistic
Equation plot -> Rendering
Eucliden – Polar -> Deformations
Exclusion -> Layers
F
Fade -> Layers
Faded array -> Arrays & frames
Fast tone mapping -> Colors
Fish-eye -> Deformations
Flower -> Deformations
Fourier analysis -> Spectral handling
Fourier transform -> Spectral handling
Fourier watermark -> Spectral handling
Freeze -> Layers
Frequency merging -> Spectral handling
Frequency splitting -> Spectral handling
Fuzzy frame -> Arrays & frames
G
Gaussian blur -> Degradations
GMic Strukture Tensors -> {Naggobot's filters}
Gradient norm -> Contours
Gradient RGB -> Contours
Grain extract -> Layers
Grain merge -> Layers
Graphic boost -> Artistic
Graphic Boost 2 -> Artistic
Graphic Colors -> {PhotoComix Filters}
Graphic novel -> Artistic
Graphic Novel 2 -> Artistic
GraphiX Colors -> {PhotoComix Filters}
Green -> Colors -> RGB Curves
GREYC Poker Tour -> Various
H
Hard light -> Layers
Hard sketch -> Black & white
Hearts -> Patterns
Heavy Screen -> {PhotoComix Filters}
High Pass -> Enhancement
Histogram anaysis -> Various
Hot pixels filtering -> Enhancement
Hough sketch -> Black & white
HSV Equalizer -> Colors
HSV mixer -> Colors
Hue -> Layers
Hue Lighten/Darken -> {Iain Fergusson's G'MIC Filters}
I
Image grid -> Arrays & frames
Import data -> Various
Ink wash -> Black & white
Interpolation -> Layers
Inverse diffusion -> Enhancement
Isophotes -> Contours
J
JPEG Smooth -> {Garagecoder's tests}
K
Kaleidoscope -> Artistic
Kuwahara -> Artistic
L
Lab mixer -> Colors
Laplacian -> Contours
Lava lamp -> Sequences
Layer Browser -> {Naggobot's filters}
Layers alignment -> Layers
Layers morphing -> Layers
Layers to tiles -> Layers
Lens Blur -> {Gentlemanbeggar's filters}
Lens Blur -> Degradations
Lenticular print -> {Tom Keil's filters} -> Sterescopic 3D
Light glow -> Lights & Shadows
Light patch -> Lights & Shadows
Light rays -> Lights & Shadows
Lighten -> Layers
Lightness -> Colors -> Lab Curves
Lightness -> Layers
Linear Blur -> Degradations
Linear gradient -> Colors
Lissajous -> Patterns
Lissajous -> Sequences
Local contrast enhancement -> {Naggobot's filters}
Local normalization -> Colors
Local orientation -> Contours
Local Similarity Mask -> {Iain Fergusson's G'MIC Filters}
Luminaance -> Colors -> YCbCr Curves
Luminace -> Layers
Lylejk's painting -> Artistic
Lylejk's stencil -> Presets / Testing
M
Make Old Squiggly -> {Naggobot's filters}
Make Squiggly -> Artistic
Make Up -> {Iain Fergusson's G'MIC Filters}
Mandelbrot / Julia sets -> Rendering
Mapped Smoothing -> {Naggobot's filters}
Marble -> Patterns
Mask Creator -> {Tom Keil's filters}
Maxfield Parrish -> {Gentlemanbeggar's filters}
Maze -> Rendering
Mean-curvature flow -> Enhancement
Median -> Layers
median 3 image stack -> {Iain Fergusson's G'MIC Filters}
median 5 image stack -> {Iain Fergusson's G'MIC Filters}
Median filtering -> Enhancement
Mescalito colors -> Artistic
Metallic look -> {Tom Keil's filters}
Metallic look -> Colors
Mirored array -> Arrays & frames
Modern Cinema -> {Gentlemanbeggar's filters}
Morphological filter -> Contours
Morphological filter -> Sequences
Morphology painting -> {Naggobot's filters}
Morphology painting -> Artistic
Mosaic -> Patterns
MS Pixel Denoise -> {Iain Fergusson's G'MIC Filters}
Multiply -> Layers
N
Negation -> Layers
nM Differences -> {KaRo's Test}
O
Object animation -> {Tom Keil's filters}
oC Differences -> {KaRo's Test}
Octave sharpening -> Enhancement
Old photograph -> Artistic
Old-movie stripes -> Degradations
Oldschool 8bits -> Degradations
Overlay -> Layers
P
Painting -> Artistic
Paper texture -> Patterns
Pastell art -> Artistic
Patch-based smoothing (16bits) -> Various -> Experimental
Path-based smoothing -> Enhancement
Pattern frame -> Arrays & frames
Pen drawing -> Artistic
Pencil -> Black & white
Perspective -> Deformations
Phoenix Steam-Pencil -> Artistic
PhotoComiX smoothing -> Presets / Testing
Photoilustration -> {Tom Keil's filters}
Photoilustration -> Artistic
Ping Pong -> {Gentlemanbeggar's filters}
Pink operator -> Various -> Experimental
Pink operator binary -> {KaRo's Test}
Pink test operator bianca -> {KaRo's Test}
Pixel denoise -> {Iain Fergusson's G'MIC Filters}
Plaid -> Patterns
Plasma -> Patterns
Polar transform -> Deformations
Polaroid -> Artistic
Polaroid -> Sequences
Polka dots -> Patterns
Posterrized dithering -> Artistic
Psychodelic Glasswork Tiler -> Artistic
Puzzle -> Patterns
Q
Quick copyright -> Various
R
Radial blur -> Degradations
Radial gradient -> Colors
Rainbow -> Rendering
Random -> Deformations
Random array -> Arrays & frames
Random color array -> Arrays & frames
Random color elipses -> Artistic
Random pattern -> Arrays & frames
Random shade stripes -> Degradations
Recursive Median -> {Iain Fergusson's G'MIC Filters}
Red -> Colors -> RGB Curves
Red chrominance -> Colors -> YCbCr Curves
Red-Eye attenuation -> Enhancement
Reflect -> Layers
Reflection -> Artistic
Region inpainting -> Enhancement
Regular array -> Arrays & frames
Regular frame -> Arrays & frames
Relief light -> Lights & Shadows
Replace color -> Colors
RGB mixer -> Colors
RGB tone -> {Iain Fergusson's G'MIC Filters}
Ripple -> Deformations
Rodilius -> Artistic
Rodilius -> Sequences
Rorschach -> Patterns
Rotoidoscope -> Artistic
Round frame -> Arrays & frames
S
Saturation -> Layers
Saturation EQ -> {Iain Fergusson's G'MIC Filters}
Scale2x algorithm -> Enhancement
Screen -> Layers
Seamlees Deco -> Patterns
Segmentation -> Contours
Select color -> Colors
Sepia -> Colors
Shadow patch -> Lights & Shadows
Shape average -> Layers
Shock filters -> Enhancement
Sierpinsky triangle -> Patterns
Simple noise canvas -> {Naggobot's filters}
Single image stereogram -> {Tom Keil's filters} -> Sterescopic 3D
Skelton -> Contours
Sketch -> Black & white
Smart upscale -> Enhancement
Snowflake -> Patterns
Soft glow -> Artistic
Soft glow -> Sequences
Soft light -> Layers
Solidify -> Enhancement
Solve maze -> Various
Sphere -> Deformations
Split tones -> Layers
Sponge -> Patterns
Spread noise -> Degradations
Stained glass -> Patterns
Stamp -> Black & white
Stamp -> Layers
Steampunk-Pencil -> Black & white
Stencil -> Black & white
Stencil -> Patterns
Stero Image -> {Garagecoder's tests}
Superformula -> Patterns
Symmetry Master -> Patterns
T
Taquin -> Arrays & frames
Tetris effect -> Artistic
Texture enhance -> {Iain Fergusson's G'MIC Filters}
Thin brush smoothing -> Presets / Testing
Thin edges -> Contours
Tileable rotation -> Arrays & frames
Tiled isolation -> Arrays & frames
Tiled normalization -> Arrays & frames
Tiled parameterization -> Arrays & frames
Tiled random shift -> Arrays & frames
Tiled rotation -> Arrays & frames
Tiles to layers -> Layers
Tone mapping -> Colors
Tone presets -> {Iain Fergusson's G'MIC Filters}
Total-variation flow -> Enhancement
Transfer colors -> Layers
Transparent difference -> Layers
Truchet -> Patterns
Tunnel -> Arrays & frames
Turbulence -> Patterns
Twirl -> Deformations
U
Unsharp mask (16bits) -> Various -> Experimental
Unsharp mask -> Enhancement
Urban Blight -> {Gentlemanbeggar's filters}
User-defined -> Colors
V
Value -> Layers
Vector Field Rotation Demo -> {Naggobot's filters}
Vintage style -> {Tom Keil's filters}
Vintage style -> Colors
Visible watermark -> Degradations
Vivid Colors -> {PhotoComix Filters}
Vivid Edges -> {PhotoComix Filters}
Vivid Screen -> {PhotoComix Filters}
W
Warhol -> Artistic
Warp test -> {Naggobot's filters}
Water -> Deformations
Watercolor -> Artistic
Wave -> Deformations
Whirl drawing -> Artistic
Whirls -> Patterns
Wild Cartoonizer -> Artistic
Wind -> Deformations
X
Xor -> Layers
Y
YAG_effect -> {Naggobot's filters}
YCbCr mixer -> Colors
Z
Zone system -> Colors
Zoom -> Deformations
Available filters (380 - 16 About= 364)
Version 1.5.1.0 [ 30.03.2012 ]
Alphabetical list of filters GMIC-30.03.2012-ods.zip [16.07 KiB]
Downloaded 168 times
 Post subject: Re: New gallery for the plug-in effects in G'MIC
PostPosted: Wed Feb 15, 2012 11:44 pm  (#2)
The gallery is great, David. It's astounding what g'mic can do.
MareroQ, your alphabetized list is outstanding. Thank you so much for taking the time to do that.
PostPosted: Thu Feb 16, 2012 2:11 am  (#3)
I like it, nicely done!
PostPosted: Thu Feb 16, 2012 5:16 am  (#4)
Very nice job. The alphabet order will be very handy, I have always had trouble remembering there to find things and this will help a lot
Excellent MareroQ
PostPosted: Thu Feb 16, 2012 10:33 am  (#5)
This is great David! Now when someone asks me what a certain effect does i can show them immediately. :)
With your permission David i would like to add this image to our Help part of the forum and sticky it. :)
I would also like to add it to my Gimp Rocks blog.
Nice list MareroQ.
PostPosted: Thu Feb 16, 2012 10:13 pm  (#6)
This is a fantastic resource!
PostPosted: Fri Feb 17, 2012 3:04 am  (#7)
Rod, of course do what you want with it !
When finishing the page, I was actually a bit disappointed because it looked like there was not much filters at all (maybe this is just a false impression..).
On the other hand, it took me hours to do all these screenshots with a "standard" view.
