It is currently Wed Aug 26, 2026 3:19 am
 Post subject: Resize and Save Image Rel 4
PostPosted: Sun Mar 04, 2012 4:01 am  (#1)
Resize and Save Image Rel 0.04 usefull for scaling, sharpening and saving image to the same location as original file.
Saves the new file as [original file name]-new width X new height.
Look in Image>Resize and Save Image, also Script-Fu>Batch Tools>Batch-Resize-and-Save-Images
File comment: Rel4
Resize and Save Image.scm [7.15 KiB]
Downloaded 157 times
 Post subject: Re: Resize and Save Image Rel 2
PostPosted: Sun Mar 04, 2012 5:20 am  (#2)
Cool! :hi5
and about the image says that can't be used on animation i believe the warning is not correct:
can't be used on layer animation (as gif) but the batch command should work very well for "Frame" animation as the animated sequences from GAP
that because frames are just images numbered sequentially and of same size,
in case of frames with only one layer i can't see why should not work.
ok clearly the warning was for gif or multilayer xcf, thank for the great script i think i will use a lot today
PostPosted: Sun Mar 04, 2012 5:32 am  (#3)
Thank you Graechan, for another one of your great scripts. That is such a cute rabbit too
PostPosted: Sun Mar 04, 2012 7:21 pm  (#4)
PhotoComix the Script was created becouse of your request so I hope it helps in some way. And Molly I'm glad you like my 'reminder rabbit'.
PostPosted: Sun Mar 04, 2012 7:44 pm  (#5)
a reminder that Easter is on its way, woo hoo, lots of chocolate.
PostPosted: Sun Mar 04, 2012 7:50 pm  (#6)
it is helping a lot !! :jumpclap
PostPosted: Mon Mar 05, 2012 2:10 am  (#7)
Thanks Graechan! :)
 Post subject: Re: Resize and Save Image Rel 3
PostPosted: Thu Nov 17, 2016 8:04 pm  (#8)
:bump by graechan for new update
 Post subject: Re: Resize and Save Image Rel 4
PostPosted: Thu Nov 17, 2016 8:57 pm  (#9)
Rel4 gives some protection in case the Plugin LQR is not installed
PostPosted: Tue Aug 01, 2017 7:54 am  (#10)
Excellent, thanks Graechan!
Operating System: ubuntu, OS Version: 10.04.3
GIMP Version: 2.6.11, experience: beginner
and at work ofcourse, wxp ....
