It is currently Sat Aug 08, 2026 6:24 am
 Post subject: 3D script or filter request
PostPosted: Thu Aug 05, 2010 4:15 am  (#1)
Is it possible to take this tutorial
viewtopic.php?p=2356#p2356
And turn it into a script (SCM) for Gimp?
Seems like the hardest part would be choosing a perspective.
 Post subject: Re: 3D script or filter request
PostPosted: Sat Aug 07, 2010 1:34 am  (#2)
Personally, I think a script detracts from the elegance of Youssef's technique. Nonetheless, here is one with which to play.
File comment: Updated script
sg-3d-ify.scm [2.57 KiB]
Downloaded 779 times
PostPosted: Sat Aug 07, 2010 2:22 am  (#3)
Thanks saulgoode! =)
Here are some results from your script. (can be found in Filters/Misc/3D-ify after install)
without perspective
with perspective
with gradient
I think it adds to the functionality myself. =)
Nice script saulgoode, very well done.I like the way you have each layer added separately so you can alpha to select the 3D layer to add gradients or patterns.
PostPosted: Sat Aug 07, 2010 3:28 am  (#4)
Here it is at -90 degrees =)
Sweeet!
-90 with gradient.
with pattern at -90
PostPosted: Sat Aug 07, 2010 11:13 am  (#5)
Here's mine using the script.
PostPosted: Sat Aug 07, 2010 10:21 pm  (#6)
Oh boy, I hope I have time to play with the script tomorrow!!!
PostPosted: Sat Aug 07, 2010 10:38 pm  (#7)
It's a nice script.
Tried my sig with it. The perspective tool on it just made it look squashed. One letter just doesn't do perspective well.
PostPosted: Sun Aug 08, 2010 1:32 am  (#8)
Excellent script! It works for more than text too! I tried it on brush drawings and it works beautifully!
My Sigs = My Photos
PostPosted: Sun Aug 08, 2010 3:25 am  (#9)
I have had to update the script (attached to this post) because of a minor problem with the positioning of the added "shadow" layer in the layerstack.
PostPosted: Sun Aug 08, 2010 10:59 am  (#10)
Thanks, saulgoode. Got the update. On the two demos I did I had moved the shadow down 2px and to the right 2px to line it up.
Not quite there yet. I moved the shadow down and to the right 1px each in the right O, left O is script result untouched.
PostPosted: Sun Aug 08, 2010 1:11 pm  (#11)
Thanks for the update saulgoode! =)
