It is currently Wed Aug 12, 2026 3:49 am
 Post subject: Using Twist plugin via PDB
PostPosted: Fri Apr 06, 2012 6:56 pm  (#1)
Does anyone know how to set up the twist plugin or know of any previous discussion on this or any site about using the twist plugin in a script.
the settings are many and vague
(plug-in-Twist 1 image image-layer
                                    0.75          ;a1
                          -6.50         ;a2
                          -2.60         ;a3
                          5.60          ;a4
                          0.20          ;a5
                          6.00          ;a6
                          -0.04         ;a7
                          0.00          ;a8
                          ()            ;lettering01
                          ()            ;lettering02
                          ()            ;lettering03
                          ()            ;lettering04
                          ()            ;lettering05
                          ()            ;lettering06
                          ()            ;lettering07
                          ()            ;lettering08
                          FALSE         ;use-cutoff
                          0.50          ;r
                          O.20          ;dr
                          06)            ;current-function
I'm not sure about what noninteractive, lettering, or current-function arguments should be.to set up for this
 Post subject: Re: Using Twist plugin via PDB
PostPosted: Fri Apr 06, 2012 7:23 pm  (#2)
It would be cool if you could automate the butterfly wings Graechan. Maybe some coders here can answer how to include this cool plugin in a Script. :)
PostPosted: Fri Apr 06, 2012 8:52 pm  (#3)
Lyle you picked up on what I was doing fast, this plugin is all I'm missing so far but have no worries like all plugins I it can be worked out
PostPosted: Sat Apr 07, 2012 10:35 pm  (#4)
Good luck with it Graechan. As far as i know this plug-in is like compiling Gimp on Windows.
The setup for the environment is hard to overcome, but once you do it just works. :)
Who knows what all these magical settings mean? It doesn't even come with a PDF manual. :\
PC explained it all quite nicely when he said it is a real pain to work with. (In not those exact words). :lol
However it does make quite beautiful butterflies and i hope you get it working correctly. :)
Personally i would use all of Lyle's settings and cheat a bit.
