It is currently Fri Aug 14, 2026 3:16 am
 Post subject: Gimpscripter plugin
PostPosted: Sun May 06, 2012 12:57 pm  (#1)
I'm wondering if anybody has had any experience with this plugin. http://registry.gimp.org/node/25305 Is it of any use to somebody with no script writing experience at all?
 Post subject: Re: Gimpscripter plugin
PostPosted: Sun May 06, 2012 1:02 pm  (#2)
if you have the patience to read its readme file, (or doc or how is called, now i don't remember)..yes !
It can help a lot to automatize repetitive tasks
So if you may read the.."how it works" may be quite useful
PostPosted: Sun May 06, 2012 1:05 pm  (#3)
Thank you, I'll give it a try.
PostPosted: Sun May 06, 2012 1:24 pm  (#4)
I wanted to create a topic bout this but I think 2.8 has something better in it.
PostPosted: Sun May 06, 2012 1:38 pm  (#5)
When 2.8 works properly.
PostPosted: Sun May 06, 2012 3:25 pm  (#6)
Well it works 99% without a hitch for me. In every software there are always bugs, even in stable builds, it is an inherit part of coding. I don't think it is right for everyone to automatically say "Oh well this part isn't fixed yet, I'm not gonna use it," especially since GIMP is open-source. They are programming this amazing piece not out of paycheck, but instead out of want. They have put so many hours into this that it is to be expected that these things would happen! If we were using a commercial software the bugs would be fixed a lot faster yes, but at the slave rate hours! Just be glad these bugs are even getting fixed! Most of the open source projects don't get worked on for years at a time.
PostPosted: Wed May 09, 2012 5:37 pm  (#7)
how do you download the plug in?
PostPosted: Wed May 09, 2012 5:50 pm  (#8)
https://github.com/bootchk/gimpscripter/archives/master
PostPosted: Thu May 10, 2012 4:00 am  (#9)
Has it been updated at all?
PostPosted: Tue Nov 19, 2013 1:23 pm  (#10)
New download link.
https://github.com/bootchk/gimpscripter ... master.zip
PostPosted: Tue Nov 19, 2013 2:28 pm  (#11)
Thanks Rod.
PostPosted: Wed Nov 20, 2013 6:31 am  (#12)
Erisian wrote:
Thanks Rod.
No problem. Some folks actually do not know how to navigate to the actual download package itself on Github so i thought it would help a bit to just post a direct link. It doesn't seem to work in GIMP-2.8.6 though. It worked fine in GIMP-2.7 versions. Does it need GLADE to run?
PostPosted: Wed Nov 20, 2013 11:21 am  (#13)
g-scripter
I probably have not used gimpscripter,
for what it was specifically designed,
but more as a list, the gui is a visual
dictionary of all menu items.
And it looks like it can be used to
put together as many of those items
into one, YourName shortcut.
Creates new ShortCut menu on Gimp's
Image Menu Bar.
