It is currently Fri Aug 14, 2026 9:26 am
 Post subject: GFXArrows - Plugins for Gimp
PostPosted: Mon May 28, 2012 3:25 pm  (#1)
Does anyone know if it's possible to get the source code for this anywhere
http://www.graphics-muse.com/gfxmuse/gfxarrows.html
 Post subject: Re: GFXArrows - Plugins for Gimp
PostPosted: Mon May 28, 2012 3:53 pm  (#2)
maybe try the waybackmachine
there are snapshots there for the site covering a few years. eg
http://web.archive.org/web/200612220423 ... w/gfxmuse/
PostPosted: Mon May 28, 2012 3:57 pm  (#3)
OK, lets's play Sherlock
- access the site
- author says source code can be downloaded
- links point to directory (http://www.graphics-muse.com/sw/gfxmuse/), but elicit "not authorized"
- could be a mistake, directory browsing forbidden
- need to get a direct URL to the file
- instructions lower in the page says to use "tar xvzf GFXMuseTools-version.tar.gz"
- current version is 3.0.0B2
- so let's put all this together and try URL: http://www.graphics-muse.com/sw/gfxmuse ... 0B2.tar.gz :clap :pengy :hi5 :coolthup :yes
PostPosted: Mon May 28, 2012 4:03 pm  (#4)
- access the site
Nice Ofnuts! :)
Good detective work.
Now to see if i can compile a working version for Gimp-2.8.
