It is currently Wed Aug 12, 2026 12:35 pm
 Post subject: Layer via Copy/Cut
PostPosted: Fri Jun 01, 2012 3:53 pm  (#1)
GIMP 2.8 Python Plug-in.
Copy and move the selected area to a new layer in the same position.
This function is similar to the functions with the same names in Photoshop, and more powerful. Unlike them, it can copy/cut content, not just from one layer, but also from the layer groups.
In Photoshop, this is not possible :)
Installation:
1. Close GIMP if it is open.
2. Extract "layer-via-copy-cut.py" from zip archive to the ".../.gimp-2.x/plug-ins" directory.
3. Run GIMP. The script should appear under the menu: "Layer > Layer via Copy" and "Layer > Layer via Cut". Don't forget to make the plugin executable.
Download:
Download from my deviantart page:
slybug.deviantart.com
Tested with GIMP 2.8.
I hope this plug-in will be useful for someone else.
Version History:
v1.5 (04.06.2012)
- Added automatic cache cleanup.
- Fixed bug with non-rectangular selection.
v1.4 (04.06.2012)
- The new layer/group is created above the original, and not at the top of the stack.
- Some code improvements.
v1.3 (01.06.2012)
- Initial release.
My other plugins:
Create Layer Mask from...
Duplicate to another Image
Scale Layer to Image Size
 Post subject: Re: Layer via Copy/Cut
PostPosted: Fri Jun 01, 2012 5:18 pm  (#2)
Thanks i will install and check it out. :)
Welcome to Gimp Chat by the way.
PostPosted: Fri Jun 01, 2012 5:25 pm  (#3)
I want to install it but have to wait until I have Gimp-2.8 in Fedora.
PostPosted: Sun Jun 03, 2012 6:20 pm  (#4)
v1.4 (04.06.2012)
PostPosted: Sun Jun 03, 2012 6:44 pm  (#5)
Thanks for the update Slybug. :)
PostPosted: Mon Jun 04, 2012 12:03 pm  (#6)
v1.5 (04.06.2012)
