It is currently Sat Aug 15, 2026 5:45 am
 Post subject: Is there a Smear Selection Type of Script
PostPosted: Thu Jun 21, 2012 1:42 pm  (#1)
What I would like to be able to do is take a sqwiggly line selection filled with a gradient and smear it across the canvass like shown in this photo screan shot.
I know I can just copy the selection to the clipboard and then use the pencil tool and draw the smear with the Ctrl and shift key to constrain it but eventually I want to add several lines together to create a height map of about 50 lines. Thats why it would be handy to have a script or something to do it automatically.
What I mean is if I draw a smear and then turn it into a straignt line and add several lines together I should be able to draw a complete human face and use it as a height map image. Drawing these contour selections with a face photo at a 45 degree angle as a template is what I want to try and do. Fill the contour selections with a gradient smear them across canvas make a strait line segment of the gradient stack them all next to each other and come out with a height map of a face.
Alan
 Post subject: Re: Is there a Smear Selection Type of Script
PostPosted: Thu Jun 21, 2012 1:58 pm  (#2)
There is a fill script somewhere here.
SG Contour fill or selection blend.
Not sure which is which right at the moment.
However both are available here
http://www.gimpscripts.com
PostPosted: Thu Jun 21, 2012 1:59 pm  (#3)
Wait i think its this one here.
http://gimpscripts.com/2012/02/rma-selection-blend/
PostPosted: Thu Jun 21, 2012 3:17 pm  (#4)
I didn't know that site existed, thanks.
PostPosted: Thu Jun 21, 2012 4:02 pm  (#5)
It's at the top of every Gimp Chat page right in the middle GMS. :hehe
