It is currently Sun Nov 29, 2026 1:19 am
Post new topic Reply to topic  [ 86 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Blue Ice Script Rel7 [with l2height-0.7 plugin]
PostPosted: Tue Jul 17, 2012 5:06 am  (#1)
Rel 0.02 - Added perspective, color and gradient fill to text
Image with darkened footprint option selected
Rel7 Menu
Menu Location Script-Fu/Logos/Blue Ice
To use you will need to install the light to Height plugin
For l2height-0.7 source l2height-0.7-source.zip
For windows version l2height-0.7-32bits-64bits.zip
To use in 2.6 you will also need the rain pattern from 2.8 that I will also post in the zip folder with script
; Rel 0.04 - Added 'Active Gradient' option in 'Text Fill' to assist Linux users
; Rel 0.05 - Improved 'Active Gradient option to use the active ff/g b/g colors and Added f/g b/g color selector for 'Gradient' option
; Rel 0.06 - Decreased Menu Box length ['FG to BG (RGB)' gradient will now use active f/g b/g colors for 'Gradient' and 'Active Gradient']
; Rel 0.07 - Added SteamPunk (with more vibrant colors) to Text fill Types
(please delete previous Blue Ice-2.8 before installing the new Rel7 Blue Ice)
BLUE ICE rel7.zip [351.18 KiB]
Downloaded 684 times
 Post subject: Re: Blue Ice Script
PostPosted: Tue Jul 17, 2012 7:00 am  (#2)
Is one of those links for Linux Graechan?
PostPosted: Tue Jul 17, 2012 8:19 am  (#3)
It's an .scm script so it will run on any OS molly.
Gerard.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
PostPosted: Tue Jul 17, 2012 9:12 am  (#4)
Thanks Gerard...I realize it is a scm and I did put it in my script folder but I get this same message over and over when I run it. I googled the error and I think it is a Windows error.
PostPosted: Tue Jul 17, 2012 9:20 am  (#5)
You just need the light 2 height plugin Molly.
The one i compiled for windows. Sam compiled one for 64 bit also. :)
PostPosted: Tue Jul 17, 2012 9:24 am  (#6)
Yes Rod but the one that samj compiled has .exe after it and I can't use exe in Fedora plug-ins. Shouldn't it have a .py extension in the plug-in file? Not .exe OR am I downloading the wrong one?
PostPosted: Tue Jul 17, 2012 11:50 am  (#7)
No you will have to use it in windows 64 bit Molly.Unless you have windows 32 bit. :)
OR
You can try compiling the c plugin in Fedora.
PostPosted: Tue Jul 17, 2012 11:57 am  (#8)
I do not know how to compile. I probably never will. I like straight out of the box, :teeth
PostPosted: Tue Jul 17, 2012 12:04 pm  (#9)
Works like a charm!
File comment: Cool Graechan
PostPosted: Tue Jul 17, 2012 3:31 pm  (#10)
Nice work, Graechan!! Text manipulation and logo scripts are one of my most used tools in the GIMP arsenal.
 Post subject: Re: Blue Ice Script Rel2
PostPosted: Wed Jul 18, 2012 12:28 am  (#11)
Release 2 just uploaded
PostPosted: Wed Jul 18, 2012 12:38 am  (#12)
Nice work. Thanks again Graechan.
Edit: Just been playing around with it.Image
PostPosted: Wed Jul 18, 2012 2:27 am  (#13)
That's why I gave up on linux, it shouldn't be that much trouble all the time. Everybody that does it tells me something so that I got so confused znd dumped linux. Point is, you're not alone.
PostPosted: Wed Jul 18, 2012 3:26 am  (#14)
Nothing to do with Linux. I am just not a programmer so needless to say I can't compile. I love Linux and I would never change back to Windoze.
PostPosted: Wed Jul 18, 2012 3:31 am  (#15)
Does this also have to be compiled for Linux Graechan?
PostPosted: Wed Jul 18, 2012 4:20 am  (#16)
Yeah, same here. I know how to do some things and I don't mind getting my hands dirty sometimes but I don't have any desire to be able to do all the things some people do.
Molly, it's a script. You just need to have that l2height plugin from the other thread.
PostPosted: Wed Jul 18, 2012 4:51 am  (#17)
It is just the update to Graechan's script that I want but compiled for Linux-64-bit
PostPosted: Wed Jul 18, 2012 7:56 am  (#18)
Simply fantastic Graechan! :)
pattern startile attached. ( 124x64 )
just place in your patterns folder. :)
startile.zip [7.54 KiB]
Downloaded 276 times
PostPosted: Wed Jul 18, 2012 7:49 pm  (#19)
Molly the Initial post has been updated to include the links for the Light to Height Linux files
PostPosted: Wed Jul 18, 2012 8:01 pm  (#20)
thank you Grachan. I didn't know that. woo hoo. love your scm's
