It is currently Sat Aug 15, 2026 4:25 am
 Post subject: watermark
PostPosted: Sat Aug 25, 2012 6:02 pm  (#1)
is there a script/gmic for making a watermark, or perhaps a tutorial?
 Post subject: Re: watermark
PostPosted: Sat Aug 25, 2012 6:04 pm  (#2)
I'm pretty sure there's a watermark filter in G'MIC. I can't remember which section it's in though.
PostPosted: Sat Aug 25, 2012 6:06 pm  (#3)
I thought so too, I thought I looked at everything, but can't find it.
PostPosted: Sat Aug 25, 2012 6:10 pm  (#4)
It's in Degradations and it's called Visible Watermark.
PostPosted: Sat Aug 25, 2012 7:11 pm  (#5)
Jolie at GimpTricks has a tutorial also 2-ton. :)
Here you go.
PostPosted: Sat Aug 25, 2012 8:43 pm  (#6)
Here's a Watermark script originally by Doug Reynolds, updated by Paul Sherman (05/05/2012 on GIMP-2.8).
FU_watermark.scm [3.25 KiB]
Downloaded 146 times
PostPosted: Sun Aug 26, 2012 10:38 pm  (#7)
thanks guys.
The g'mic one is easy....and has some nice choices. Just gotta remember it goes onto the active layer, so a new layer blank would be a good thing to put it on.
PostPosted: Sun Aug 26, 2012 11:36 pm  (#8)
In the G'mic window Input/Output section, change the Output to new layer...
