It is currently Sun Nov 29, 2026 5:23 am
Post new topic Reply to topic  [ 62 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Crayon-Text version 1 (SCM)
PostPosted: Sun Aug 26, 2012 12:10 pm  (#1)
Font Face is "URW Gothic L Semi-Bold"
Seems to need some distortion perhaps? It looks too perfect for hand drawn crayon.
Any ideas? :)
 Post subject: Re: I am testing a new crayon effect script
PostPosted: Sun Aug 26, 2012 12:43 pm  (#2)
Try it on a hand script font of some kind Rod. It might be easier to see what needs doing if it looks like scrawl.
PostPosted: Sun Aug 26, 2012 1:34 pm  (#3)
I believe i have it finished.
Here is text at 1000x400 pixels
Here is text at 700x250
Script has 2 values
color - your crayon color
Messiness - values range from 1-5
Will be located at Script-Fu>Text Effects>Crayon Text
Script is attached
crayon-text_RD-v1.0.scm [3.63 KiB]
Downloaded 412 times
Please let me know what could be fixed or changed.
Thanks!
Enjoy!
PostPosted: Sun Aug 26, 2012 1:46 pm  (#4)
Another font face example "URW Palladio L Bold Italic"
I think i captured the effect pretty well. :)
 Post subject: Re: Crayon-Text version 1 (SCM)
PostPosted: Sun Aug 26, 2012 2:30 pm  (#5)
One for Molly. :)
PostPosted: Sun Aug 26, 2012 3:04 pm  (#6)
How about an alpha to logo addition? It would useful for creating that little kid drawn picture effect :D
PostPosted: Sun Aug 26, 2012 3:18 pm  (#7)
That is really good Rod.
PostPosted: Sun Aug 26, 2012 6:08 pm  (#8)
I'm going to have to really study that Text tool. I wanted to put the little guy on a separate layer. I put a transparent layer on top of the first text, it wouldn't let me add a separate text layer. It kept bring up the text editor.
Made a new image to make the little guy. :\
Fun script, Rod. :jumpclap
Although I didn't need to, I used a crayon font from dafont.
http://www.dafont.com/dk-crayon-crumble.font
PostPosted: Sun Aug 26, 2012 6:33 pm  (#9)
You can already with this script.
Just draw out your picture (on separate layers if you want dif colors) like a brown tree and green shrubbery.
Maybe a blue sky?The script just needs an alpha area on the layer.So if you paint out a black cloud and run the script and select white, it will color the cloud white but it doesn't look that great on a white bg. (barely visible)
If you paint out a tree trunk on a transparent layer it will paint the tree trunk the color you have chosen...and so on.
It was made primarily for text as it was needed in the past and i couldn't find one free commercial use type font face out there.
If you use black it will pick itself and delete it's own color so black doesn't work at the moment. :lol
I am working on that part of the script now.White works but it is barely visible.
The script breaks the colors into very tiny pieces of color with a lot of alpha area.So it looks best on a white bg.
I will keep working on it and try to get something better to work with.
Maybe a color book script. :)
Thanks for the kind comments everyone. :tyspin
PostPosted: Sun Aug 26, 2012 7:03 pm  (#10)
i really liked playing with the crayon effect, it will make some really nice stuff.
PostPosted: Sun Aug 26, 2012 7:53 pm  (#11)
Imagethis is what i get when i try it :/
PostPosted: Sun Aug 26, 2012 8:12 pm  (#12)
Pirate, Rod's script is apparently designed to only work with GIMP version 2.8 or later.
PostPosted: Sun Aug 26, 2012 8:13 pm  (#13)
saul,
ok thank you
i'm still with 2.6
Appreciate the heads up
PostPosted: Sun Aug 26, 2012 8:41 pm  (#14)
great script...and everyone's test look really good!
PostPosted: Sun Aug 26, 2012 9:39 pm  (#15)
Sorry about that Pirate i do not have gimp-2.6 installed right at this time.
For now you should be able to change the two lines that read -
(gimp-image-select-item image 0 layer)
to -
(gimp-selection-layer-alpha image 0 layer)
I think that's correct.
Then it should run ok after that. :)
PostPosted: Sun Aug 26, 2012 10:37 pm  (#16)
hi Rod
Thank you for replying.
When i open the codes with notepad,
(gimp-image-select-item image 0 layer) is in there 4 times,not twice.
I tried to change all 4 and when i saved it again,the icon was not showing an scm file anymore,it just showed Gimp logo .I know ,as usual,that I am doing something wrong,but I don't know what :)
PostPosted: Sun Aug 26, 2012 10:55 pm  (#17)
Pirate can you try this one for me?
Make sure you remove the other one first. :)
crayon-text_gimp-2.6_RD-v1.0.scm
PostPosted: Sun Aug 26, 2012 11:48 pm  (#18)
Rod,
I get this now :)
PostPosted: Mon Aug 27, 2012 10:23 am  (#19)
I tested it on 2.6.11.
PostPosted: Mon Aug 27, 2012 5:54 pm  (#20)
At least I got a block of crayon even though I lost the text. You're getting there Rod. :hehe
