It is currently Sun Aug 09, 2026 11:23 am
 Post subject: Wills new wood script plug-in
PostPosted: Mon Sep 20, 2010 1:25 pm  (#1)
pretty cool results..
http://registry.gimp.org/node/24729
 Post subject: Re: Wills new wood script plug-in
PostPosted: Mon Sep 20, 2010 1:33 pm  (#2)
I asked if the creator might add a option in the script dialog to use current gradient colors, or tool colors.
That would be a fine addition to the script i think.
PostPosted: Mon Sep 20, 2010 7:07 pm  (#3)
It's unfortunate it won't use the current gradient. Also, I'd really prefer that it ended up with an alpha channel. The layers are flattened.
Here's my attempt at plywood.
PostPosted: Mon Sep 20, 2010 8:58 pm  (#4)
If I need wood textures i use wood workshop, it's the est for what it does.
PostPosted: Tue Sep 21, 2010 8:25 am  (#5)
Wood Shop is a great tool, it would be nice if it had its own Gimp Plug-in. =)
This script is real nice for creating quick wood though.
PostPosted: Tue Sep 21, 2010 9:44 am  (#6)
Yes, I agree, that company has scandalously high prices and they're now very nice so I don't expect any changes in policy from them.
PostPosted: Tue Sep 21, 2010 11:11 am  (#7)
PostPosted: Tue Sep 21, 2010 1:06 pm  (#8)
It looks like it is supposed to use the colors, but just doesn't. When I select the FG-BG gradient, it always selects black and white. I used it to create this image (using only the FG-BG Gradient).
I created 3 images (B&W) and composed them into a single, colorful image. I duplicated the layer, rotated the copy 90 degrees and set the mode to value.
My Sigs = My Photos
PostPosted: Tue Sep 21, 2010 2:08 pm  (#9)
A few steps further.
My Sigs = My Photos
PostPosted: Tue Sep 21, 2010 2:36 pm  (#10)
Wow, Greg. I had no idea you could start out with 3 black and white layers and compose them (after changing image to grayscale). What a surprise.
Mine doesn't look much like your original image but I'm delighted with the outcome.
PostPosted: Tue Sep 21, 2010 4:40 pm  (#11)
PS there is a alternative version now http://registry.gimp.org/files/sf-will- ... adient.scm
That allow to change gradient and colors
The other is still available (well is better for who want go straight to get realistic wood...the other give more options ,but with many options is easy get confused)
PostPosted: Thu Sep 23, 2010 1:08 am  (#12)
thank you...thank you...thank you PC! =)
i've downloaded it, and will play around with the variables some.
PostPosted: Fri Sep 24, 2010 3:21 am  (#13)
Thanks for the link PC; like using a custom gradient. A little texturizing and it does come pretty close to looking like wood. :)
PostPosted: Fri Sep 24, 2010 10:05 am  (#14)
yup sure does, looks like oak grain......
PostPosted: Sat Sep 25, 2010 8:41 pm  (#15)
Very nice. =)
PostPosted: Sat Sep 25, 2010 8:44 pm  (#16)
Very well done!
My Sigs = My Photos
